#1 Posted : Tuesday, 22 February 2005 5:52:30 AM(UTC)
Gday Guys, I just had extractors and a sports system(2")put on my wagon (6 cyl. which had a stock exhaust before))and now it is pinging like crazy!, is this usual and what can I do about it? do I need to rejet the carby(stock stromy)or retard the timing slightly(electronic)I really need help here this is driving me crazy.
#2 Posted : Tuesday, 22 February 2005 8:50:47 PM(UTC)
Try adjusting the fuel mixture screw a little to give a slightly richer mixture (if yours is adjustable some are sealed and can't be moved!). If not then retard the timing a little to see if that helps. Otherwise you may need the dizzy reset to reduce the
#3 Posted : Tuesday, 22 February 2005 8:50:47 PM(UTC)
Try adjusting the fuel mixture screw a little to give a slightly richer mixture (if yours is adjustable some are sealed and cant be moved!). If not then retard the timing a little to see if that helps. Otherwise you may need the dizzy reset to reduce the
#4 Posted : Wednesday, 23 February 2005 4:24:05 AM(UTC)
Thanks Peter,
One thing, I thought the mixture screw only adjusted the idle mixture and it doesnt ping at idle only on acceleration, also is it a big job to get the dizzy reset and where would you get it done? a specialist place or would any mechanic
#5 Posted : Wednesday, 23 February 2005 7:58:54 PM(UTC)
Hi Todd,
I have a similar setup to you... 202, 2" extractors, stock stromberg carby, and electronic ignition. I had the engine rebuilt some time ago, but left the stock carby and electronic ignition as it was... it was pinging badly.
Finally took
#6 Posted: : Friday, 25 February 2005 3:17:11 AM(UTC)
Try Dynotuning places, carby and ignition specialists. Most general mechanics don't do it thse days. Beware, many places these days can be dodgy. The most important factor when you take it to them is to have the fuel tank full of the type of petrol that y
#7 Posted : Friday, 25 February 2005 3:17:11 AM(UTC)
Try Dynotuning places, carby and ignition specialists. Most general mechanics dont do it thse days. Beware, many places these days can be dodgy. The most important factor when you take it to them is to have the fuel tank full of the type of petrol that yo
#8 Posted : Saturday, 26 February 2005 2:33:35 AM(UTC)
Geez what an improvement in economy, good work!!
Peter
#9 Posted : Saturday, 26 February 2005 2:58:37 AM(UTC)
G'day Paul, Thanks that helps a lot, if you still had that aparatus you used I would pay you to do mine if you are anywhere Sydney, or somewhere in between because I spend about 4 months a year there for work. Surorisingly there are few GOOD people in Syd
#10 Posted : Saturday, 26 February 2005 2:58:37 AM(UTC)
Gday Paul, Thanks that helps a lot, if you still had that aparatus you used I would pay you to do mine if you are anywhere Sydney, or somewhere in between because I spend about 4 months a year there for work. Surorisingly there are few GOOD people in Sydn
#11 Posted : Saturday, 26 February 2005 9:57:01 PM(UTC)
Hi Todd,
I do still have the machine. It ws pretty easy to build actually, about a day. The main difference between me doing my own an a dynotuning place is that I did it by trial and error and was lucky to get it first go. I plotted the advance curve
#12 Posted : Sunday, 27 February 2005 6:01:19 AM(UTC)
Hi Paul,
Yeah no worries, I just thought Id ask, I didnt realise it was that involved, if you could find his details that would be great. Thanks.
Todd
#13 Posted : Sunday, 27 February 2005 6:01:19 AM(UTC)
Hi Paul,
Yeah no worries, I just thought I'd ask, I didnt realise it was that involved, if you could find his details that would be great. Thanks.
Todd
#14 Posted : Sunday, 27 February 2005 6:30:34 PM(UTC)
Hi Todd,
Yeah, mine was involved because it had the wrong springs etc in it to start with. I had to recurve a pollution dizzy to match my pre-pollution motor. Your dizzy may be much simpler.
The blokes name is Fred Dudek and his business is called
#15 Posted : Wednesday, 2 March 2005 6:07:23 AM(UTC)
Originally posted by Paul E
Hi Todd,
#16 Posted : Friday, 4 March 2005 3:42:17 AM(UTC)
Get a genuine factory holden manual and look in the ignition section at the back.
Paul E
#17 Posted : Friday, 4 March 2005 3:49:32 AM(UTC)
My manual has the specs for a 202 red motor, 253 and 308 V8's 350 V8 etc and is the HQ factory multi-volume manual - pre pollution. The factory curve is only good for a near stock motor and you would be lucky if it worked even then with the fuel nowadays.
#18 Posted : Friday, 4 March 2005 3:49:32 AM(UTC)
My manual has the specs for a 202 red motor, 253 and 308 V8s 350 V8 etc and is the HQ factory multi-volume manual - pre pollution. The factory curve is only good for a near stock motor and you would be lucky if it worked even then with the fuel nowadays.
#19 Posted : Friday, 4 March 2005 4:09:50 AM(UTC)
Hi Guys.
What Paul E is saying is correct. It's one thing to recurve the dissy it's another thing to get it suit your needs. It's also very labour intensive.
There is no factory manual for HX or HZ but I can get you the stock specs. These are no goo
#20 Posted : Friday, 4 March 2005 4:09:50 AM(UTC)
Hi Guys.
What Paul E is saying is correct. Its one thing to recurve the dissy its another thing to get it suit your needs. Its also very labour intensive.
There is no factory manual for HX or HZ but I can get you the stock specs. These are no good t
Guest (13)
This page was generated in 0.092 seconds.
