#1 Posted : Monday, 14 March 2005 2:52:00 AM(UTC)
i just bought i 5" monster tacho for my VR calais. but i cant get the tacho signal to work. i have tried tacking it from the pack itself, the plug behind the passenger side strut tower and behind the instrument cluster. the back light works which means there is power and all but no signal. can anyone help me make this work.
johnno
#2 Posted : Monday, 14 March 2005 11:58:55 AM(UTC)
probably a stupid question, but what have you got it hooked up to? the original tacho wires or did you wire it separately
#3 Posted : Tuesday, 15 March 2005 3:43:22 AM(UTC)
hook it up to the signal terminal behind the speedo.
it will say "ign" on one of the plugs behind your gauge cluster(the bit thats pushes into the actual dash)
follow that track back till you find a small brass nut 6-8mm?
hook it up there.
#4 Posted : Tuesday, 15 March 2005 9:17:14 AM(UTC)
ben,
i tried both straight fomr the pack and from the org tacho signal.
#5 Posted : Tuesday, 15 March 2005 9:19:01 AM(UTC)
fatboy,
i did that and it dosnt work. there is power there, the back light is there and i can set the shift light but i can get the signal. i tried it on my mates sillycar and i works so i know it's not broken
Jim Briar Hill Offline
#6 Posted : Wednesday, 16 March 2005 3:06:21 AM(UTC)
Jim Briar Hill
Views messages in topic : 96
Hi
Just a quick question how many wires are coming out of the unit????
three or more?????
#7 Posted : Wednesday, 16 March 2005 8:38:29 AM(UTC)
are you hokking the right wires up?
no offence but do you know which is which?
if it works on your mates car it should work on yours.
either your wiring is wrong or not conecting properly (earth?)
or you have found the wrong point to hook up the signa
#8 Posted : Thursday, 17 March 2005 9:01:44 AM(UTC)
there are three wires jim.
red-active
black-earth
green-tacho signal
#9 Posted : Friday, 18 March 2005 5:24:52 AM(UTC)
red is illumination, connects to the park lights
DO NOT WRITE BELOW THIS LINE
#10 Posted : Saturday, 19 March 2005 4:29:06 AM(UTC)
fatboy
its actually any active feed. ie ign, lamps, pwr windows.
#11 Posted : Sunday, 20 March 2005 2:09:26 AM(UTC)
Jim Briar Hill
Hi Johnno.
Three wires are red active power feed ( when ign is in the run/on )
black is the earth or ground/neg.
green is the signal and sould be wired to the neg post of your coil only. The night lights will not be part of the wire loom, they will be
#12 Posted : Friday, 25 March 2005 10:51:05 AM(UTC)
thanks jim,
you did help me. that thing about false readings, the coil only puts out 0.74 or a volt wich is **** all. (i know i'm a sparkie by trade). it needs to be at least 5volts. so i'm on the hunt for a signal amp.
but thanks mate
This page was generated in 0.095 seconds.
