#1 Posted : Monday, 4 April 2005 10:20:16 PM(UTC)
Guys
There's an old dude that lives around the corner from my mate's place, north of Tamworth. We help him out from time to time and I go up there regularly so I get him bits he needs from down here (Newcastle). He's currently putting a VS V6 engine (S1 or 2) into a Jackeroo. He's asked me to get him an ECU. I haven't had much V6 experience, only V8. I think the following is correct:
If it's a manual, the Delco 808 will plug into the harness, thus negating the need for a BCM mod. Will it need a new Memcal or will the VN/VP one run it?
If it's an auto he'll need to run the VS ECU and get a BCM mod done. Is this correct?
Any other stuff to be aware of?
#2 Posted : Tuesday, 5 April 2005 3:51:59 AM(UTC)
Hi Byron.
The problem here is that there is no 'off-the-shelf' memcal that can run a VS V6 (Ecotec) using an 808 Delco. You would have to buy a custom mem-cal.
It probably easier just to use the normal VS V6 sequential ECU & get the mem-cal modified
666 Offline
#3 Posted : Wednesday, 6 April 2005 9:48:56 PM(UTC)
666
Byron,
You may alreddy know, but check out www.kalmaker.com.au - they have good info/products on grafting Fuel Inj systems.
666
666
