Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
Guys
There's an old dude that lives around the corner from my mate's place, north of Tamworth. We help him out from time to time and I go up there regularly so I get him bits he needs from down here (Newcastle). He's currently putting a VS V6 engine (S1 or 2) into a Jackeroo. He's asked me to get him an ECU. I haven't had much V6 experience, only V8. I think the following is correct:
If it's a manual, the Delco 808 will plug into the harness, thus negating the need for a BCM mod. Will it need a new Memcal or will the VN/VP one run it?
If it's an auto he'll need to run the VS ECU and get a BCM mod done. Is this correct?
Any other stuff to be aware of? |
Hi Byron.
The problem here is that there is no 'off-the-shelf' memcal that can run a VS V6 (Ecotec) using an 808 Delco. You would have to buy a custom mem-cal.
It probably easier just to use the normal VS V6 sequential ECU & get the mem-cal modified |
Byron, You may alreddy know, but check out www.kalmaker.com.au - they have good info/products on grafting Fuel Inj systems. 666 |
666 |
