#1 Posted : Tuesday, 31 May 2005 6:30:46 AM(UTC)
Another basic one, sorry, but my passenger side wing mirror almost flaps around on the end of the ball type fixture - won't hold a position. Danger of scraping a very lovely paint job! Driver's sides is stiff (good). Is there some sort of easy fix? Thanks. Toby.
trubluhq Offline
#2 Posted : Tuesday, 31 May 2005 7:57:22 AM(UTC)
trubluhq
Tighten the screws on the mirror or replace it with a better one. Tighten the support nut too. Open the window to do that one. Cost u around $5.00 at the wreckers..Torana Gemini has the same unit.
John
#3 Posted : Tuesday, 31 May 2005 6:51:03 PM(UTC)
John
Thanks - screws don't seem to be helping so will hunt down a replacement (tho it looks pretty 'new'). I wondered if you could somehow gum up the balljoint area so it stiffened up. Toby.
Taz2 Offline
#4 Posted : Wednesday, 1 June 2005 4:30:04 PM(UTC)
Taz2
Not sure if it will work, but you could try "belt grip" sprayed on the ball joint....comes in a spray can.
In thrust we trust
#5 Posted : Wednesday, 1 June 2005 9:07:10 PM(UTC)
Toby,
I'll need to confirm its availability, but I may have a passenger's side HQ - HZ door mirror for sale. It has some pitting on the inside of the arm and the back of the mirror head needs a polish but it isn't floppy and comes with all screws and a
#6 Posted : Thursday, 2 June 2005 6:10:17 AM(UTC)
Dave
Fatherinlaw arrives Sat, more mechanically minded than me, will see whether he can find a fix, if not will follow up with you on this thread.
Thanks for the various suggestions.
Toby.
#7 Posted : Thursday, 2 June 2005 6:55:10 AM(UTC)
No worries Toby. I'll keep it safe until then...
Cheers...Dave
#8 Posted : Thursday, 2 June 2005 7:34:48 AM(UTC)
cheap 'n nasty 'n desperate fix - bit of epoxy glue... ;)
#9 Posted : Thursday, 2 June 2005 8:28:34 AM(UTC)
Don't tell him that Elton...he may buy my mirror, mate... :-)
Cheers...Dave
#10 Posted : Thursday, 2 June 2005 11:08:15 PM(UTC)
of course glueing it makes it non-adjustable ;)
Tour Director Offline
#11 Posted : Friday, 3 June 2005 4:57:04 AM(UTC)
Tour Director
The three screws on the rear of the actual mirror will pull a plate up against the mirror screw end and tighten it from being loose.provided that they haven't been undone before and the plate slipped loose, then it doesn't matter how hard you try you will
#12 Posted : Monday, 6 June 2005 6:29:54 AM(UTC)
You can't bet 5 minute 2 pack epoxy glue, make sure its in the correct position first you have a minute before it goes hard. You sit in the car and get a helper to adjust the mirror then using masking tape to hole it in position for 12 hours. Problem solv
Guest (7)
