14 Pages«<7891011>»
#161 Posted : Wednesday, 22 February 2006 4:39:47 AM(UTC)
bit to much fiddling around for me, i'd rather buy a stroker crank.
Live Fast, Die Sideways
#162 Posted : Wednesday, 22 February 2006 4:39:47 AM(UTC)
bit to much fiddling around for me, id rather buy a stroker crank.
#163 Posted : Wednesday, 22 February 2006 4:47:46 AM(UTC)
what are stroker cranks worth to buy? and what sizes can you get them in?
#164 Posted : Wednesday, 22 February 2006 4:58:24 AM(UTC)
Honestly i dont know, im yet to find i place that makes them for a 202.
i know someone who is selling a reground 202 crank here are the specs-
Conrod size -.020" Main bearing size - .010"
would this crank give any extra stroke? and can standar
#165 Posted : Wednesday, 22 February 2006 4:58:24 AM(UTC)
Honestly i don't know, i'm yet to find i place that makes them for a 202.
CherryBomb Offline
#166 Posted : Wednesday, 22 February 2006 5:43:58 AM(UTC)
CherryBomb
Rods for the Six's I dont know? Doubt they'd be holdens. For the 8s they use something like the Hemi six rods. If the Deck height from the Cranks center line measures the same as the holden six's then you'll use the 221 rods. Then you have to find wrist p
Never stop being inspired,
CherryBomb Offline
#167 Posted : Wednesday, 22 February 2006 5:43:58 AM(UTC)
CherryBomb
Rods for the Sixs I dont know? Doubt theyd be holdens. For the 8s they use something like the Hemi six rods. If the Deck height from the Cranks center line measures the same as the holden sixs then youll use the 221 rods. Then you have to find wrist pins.
#168 Posted : Wednesday, 22 February 2006 8:40:44 AM(UTC)
The Starfire and black/blue rods are the same. The Ford crank they cut the flywheel end off and weld a Holden one on. (I reckon it would be cheaper and easier to adapt a ford flywheel).They work out about $600 I believe. Dont know what rods they use.
#169 Posted : Wednesday, 22 February 2006 8:40:44 AM(UTC)
The Starfire and black/blue rods are the same. The Ford crank they cut the flywheel end off and weld a Holden one on. (I reckon it would be cheaper and easier to adapt a ford flywheel).They work out about $600 I believe. Don't know what rods they use.
CherryBomb Offline
#170 Posted : Thursday, 23 February 2006 3:49:57 AM(UTC)
CherryBomb
What about the Ring Gears teeth John? Do/ would they match the Holden starters?
This would relate to the Fords F/ wheel size too. Retro fitting the Holden ring gear on the Ford Wheel may be a bit trying.
Do you know of this being done mate?
Dan
CherryBomb Offline
#171 Posted : Thursday, 23 February 2006 3:49:57 AM(UTC)
CherryBomb
What about the Ring Gear's teeth John? Do/ would they match the Holden starters?
Dan
#172 Posted : Thursday, 23 February 2006 6:20:52 AM(UTC)
im looking at getting the 221 crank and getting the holden end put on, then all i need to do is find out what rods i can use then i will be laughing all the way down the strip.
gtr235 Offline
#173 Posted : Friday, 24 February 2006 12:19:06 AM(UTC)
gtr235
I have a 235 stroker in my LC GTR utilising the ford 221 crank. Basically as already stated the 221 crank is cut and welded to allow for the holden flywheel and balancer. To get 235 cubes you need to use Starfire/blue/black rods and falcon pistons. The
#174 Posted : Friday, 24 February 2006 2:39:26 AM(UTC)
would this crank give any extra stroke? and can standard cranks be reground to give extra stroke, if so how much more stroke can be gained?
Back to top
#175 Posted : Friday, 24 February 2006 3:51:18 AM(UTC)
byron engeneering makes the stroker kits i think!
or it could be bryant
something like that
Nothing beats cubic inches !!!
#176 Posted : Thursday, 9 March 2006 10:36:49 PM(UTC)
yer im not 100% sure what im going to do yet. Using the ford crank sounds like its going to take a lot of stuffing around and in the end that will most likely add up to big $$$
CherryBomb Offline
#177 Posted : Thursday, 9 March 2006 10:48:21 PM(UTC)
CherryBomb
It will if you cant find them in ready sorted kit Form.
And at the end of the day, You only need enough Power to smoke the hides.
Dan
#178 Posted : Thursday, 9 March 2006 10:54:43 PM(UTC)
thats what im thinken, do everything i can to the motor, and if im still not happy then consider stroking it.
CherryBomb Offline
#179 Posted : Thursday, 9 March 2006 11:13:30 PM(UTC)
CherryBomb
Well theres plenty you could do! It will become a matter of how much your willing to spend, before your happy, Or move on? lol
Over all, Once the car is in action, You or any one els for that matter, will never know the Diff between a 180HP Red six or
CherryBomb Offline
#180 Posted : Thursday, 9 March 2006 11:13:30 PM(UTC)
CherryBomb
Well there's plenty you could do! It will become a matter of how much your willing to spend, before your happy, Or move on? lol
Guest (36)
14 Pages«<7891011>»
This page was generated in 0.080 seconds.
