Taz2 Offline
#1 Posted : Friday, 21 October 2005 3:51:42 AM(UTC)
Taz2
Just bought a VP manual V6 ute.
Can I just swap the level 1 dash for a VP level 2 dash, or do I need the dash loom as well?
In thrust we trust
#2 Posted : Friday, 21 October 2005 5:17:40 AM(UTC)
Level 2 are plug & play into level 1, no probs at all.
Only use VN/VP ones in it, as VR & VS will not work & damage will occur.
A lot of people aim to achieve no
Taz2 Offline
#3 Posted : Friday, 21 October 2005 6:02:18 AM(UTC)
Taz2
Thanks Mick :-)
Yeah....I know about the later ones.
Bruce
In thrust we trust
#4 Posted : Friday, 21 October 2005 8:17:15 PM(UTC)
If you use a VN cluster in a VP you probably won't have the "press remote" light I may be wrong here though. Anyway even without that light the incessant beeping will tell you to press the damn remote button.
Taz2 Offline
#5 Posted : Saturday, 22 October 2005 2:45:21 PM(UTC)
Taz2
Thanks Jim.
I've put a VP level 2 dash in....and it works fine.
However the interior light doesn't work.
I didn't try the light before the swap...light just stays on now irrespective of what position the dash switch is in.
I'll install the original sw
In thrust we trust
#6 Posted : Saturday, 22 October 2005 6:01:55 PM(UTC)
Just be careful that the donor car didn't run a BCM, as some VP Berlina spec cars did.
These cars had different satellite switches because of it (things like wiper intermittent won't work etc). Could be a reason for the interior light.
Mic
Taz2 Offline
#7 Posted : Sunday, 23 October 2005 6:23:26 AM(UTC)
Taz2
Thanks Mick.
Everything is working fine so far.
Interior light is fine....I didn't allow for the time delay for the light to go off after closing the door :-(
Haven't actually checked for a BCM in either car, but will do so tomorrow.
In thrust we trust
#8 Posted : Sunday, 23 October 2005 6:40:45 AM(UTC)
The ute won't have one, but the Berlina might (if it was LX spec as a base).
The LX also got the trip computer dash & climate, as well as full electrics - that will help you judge it.
__________________________________________________
Guest (8)
