Just bought a VP manual V6 ute. Can I just swap the level 1 dash for a VP level 2 dash, or do I need the dash loom as well?
In thrust we trust |
Level 2 are plug & play into level 1, no probs at all.
Only use VN/VP ones in it, as VR & VS will not work & damage will occur.
A lot of people aim to achieve no |
Thanks Mick :-) Yeah....I know about the later ones. Cheers Bruce |
If you use a VN cluster in a VP you probably won't have the "press remote" light I may be wrong here though. Anyway even without that light the incessant beeping will tell you to press the damn remote button. |
Thanks Jim. I've put a VP level 2 dash in....and it works fine. However the interior light doesn't work. I didn't try the light before the swap...light just stays on now irrespective of what position the dash switch is in. I'll install the original sw |
Just be careful that the donor car didn't run a BCM, as some VP Berlina spec cars did. These cars had different satellite switches because of it (things like wiper intermittent won't work etc). Could be a reason for the interior light.
Mic |
Thanks Mick. Everything is working fine so far. Interior light is fine....I didn't allow for the time delay for the light to go off after closing the door :-( Haven't actually checked for a BCM in either car, but will do so tomorrow. |
The ute won't have one, but the Berlina might (if it was LX spec as a base). The LX also got the trip computer dash & climate, as well as full electrics - that will help you judge it.
Mick __________________________________________________ |
