peterwmh Offline
#1 Posted : Wednesday, 21 December 2005 7:57:13 AM(UTC)
peterwmh
Hi all,
Well I thought I had fixed the problem as the one way valve was sticking, however I still chugg a fair bit on petrol (especially uphill) and the diaphram in the Sprintgas lid doesn't open much at all, however it will hold open if I lift it up by hand with the car idling on petrol. Question I have is should I be able to lift the lid by mouth suction on the pipe? I can't and I think I can hear air at the diaphram while I try. Are these a replaceable item?? Any other ideas on what it might be?
Ta
Peter
Never late with a 308!!
#2 Posted : Wednesday, 21 December 2005 9:48:21 AM(UTC)
The sprintgas mixer is a very bad design, you should remove it and repace it with a impco setup.It sounds to me that the diaphram is split in the mixer. If u replace it with a impco mixer you will have to replace the convertor as well. Impco systems use a
#3 Posted : Wednesday, 21 December 2005 7:05:08 PM(UTC)
Take it to an Impco installer they are the best systems I have one on my 202 red powered 73 Premier for years, no problems ever.
EAP
peterwmh Offline
#4 Posted : Wednesday, 21 December 2005 7:31:28 PM(UTC)
peterwmh
Thanks guys, might have to do that long term, but I need to get it working for the trip away over Christmas in the meantime. It's definately the mixer, I have tried alternate vacuum sources, checked all the pipework etc etc but the dam lid won't lift!!
peterwmh Offline
#5 Posted : Wednesday, 21 December 2005 9:32:11 PM(UTC)
peterwmh
Have sourced an 4bbl Impco snorkel and gas convertor from a local wrecker for $50, so that was a good score. So that will be installed in the new year. Will just try to get the existing one working enough to get through Xmas in the meantime!!
