2 Pages<12
#21 Posted : Friday, 17 August 2007 6:13:50 AM(UTC)
joke nsme - yes its hilarious. you are soooo clever. I sugest you find a fagot on an anonomous site
t,,ttt,,,tttourettes,,,,
#22 Posted : Friday, 17 August 2007 6:13:50 AM(UTC)
joke nsme - yes it's hilarious. you are soooo clever. I 'sugest' you find a 'fagot' on an 'anonomous' site
arse_wipe Offline
#23 Posted : Friday, 17 August 2007 6:22:01 AM(UTC)
arse_wipe
Another thing to check,,
Most often the face of the pump will warp with age and people overtightening the bolts,,
Run a straight edge accross the pump, (normally the lower section is the one that leaks the most), and check to make sure it is straight,,,
John
Silence is non-committal
basketcasebear Offline
#24 Posted : Friday, 17 August 2007 6:25:08 AM(UTC)
basketcasebear
Now, what we need here is a judge!!!!
I accept,,,Judge Fallingbear,!!!!
my decision is hereby handed down,,
Mr Arse Wipe, has the right to call himself anything he chooses, unless it is insulting to another group person etc..
I have been called an a
DOH!!!
arse_wipe Offline
#25 Posted : Friday, 17 August 2007 6:38:23 AM(UTC)
arse_wipe
Fallingbear,
The Avatars I just downloaded a pack of adult smilies from somewhere,
I can share if anybody wants them,,,,
John
John
#26 Posted : Friday, 17 August 2007 5:53:16 PM(UTC)
Hi Guys.
Well said FB & thank you Mr wipe for not only fixing your avatar, but also providing intelligent input to the topic at hand.
By the way, I've been working on Holden 6s for over 40 years & have never had an issue with oil leaking at the fue
#27 Posted : Friday, 17 August 2007 5:53:16 PM(UTC)
Hi Guys.
By the way, Ive been working on Holden 6s for over 40 years & have never had an issue with oil leaking at the fuel
jabba Offline
#28 Posted : Friday, 17 August 2007 7:17:01 PM(UTC)
jabba
Back to issue at hand, agree with HGPREM, that Hylomar is the jobbie for fuel / oil applications as a gasketting compound. I have found another product which is even more aggressive. Is called "Seal All" and is comes in a yellow tube. Is more of a glue
#29 Posted : Friday, 17 August 2007 7:19:43 PM(UTC)
Another leak I have found on red motor fuel pumps is were the pivot pin fits in. The little core plugs can leak and or fall out. But normally it is what arse_wipe said about the pump bending with age or what Dr Terry said about the internal seal leaking a
JBM Offline
#30 Posted : Friday, 17 August 2007 7:34:38 PM(UTC)
JBM
Finally back on topic, I'd forgotten what it was.
James
JBM Offline
#31 Posted : Friday, 17 August 2007 7:34:38 PM(UTC)
JBM
Finally back on topic, Id forgotten what it was.
James
Guest (15)
2 Pages<12
This page was generated in 0.183 seconds.
