#1 Posted : Thursday, 2 October 2008 1:03:00 AM(UTC)
I just picked up a VN with 300K on the clock(one lady owner).
The motor has a rattle at idle. It is definatly internal, and sounds like a shaft of some sort.
Can anyone tell me if these motors are known for this, and if so, what it would be.
Cheers.
#2 Posted : Thursday, 2 October 2008 5:21:38 AM(UTC)
300 thousand on a VN its bad news Id say dump it and buy a more modern one.
#3 Posted : Thursday, 2 October 2008 4:23:33 PM(UTC)
Rattle would most likely be the timing chain, particularly with those km on it.
Theres also a balance shaft inside them thats driven off the cam timing system too.
And also, the auto boxes in them can be a bit noisy with high km, so that could also be s
#4 Posted : Thursday, 2 October 2008 9:20:34 PM(UTC)
I know that you say its definitely internal but its also possible that you could be lucky and find out its the water pump bearings.
Slip the serpentine belt off and start the engine and see if the noise goes away.
300,000 if its had regular se
Edited by user Thursday, 2 October 2008 9:21:32 PM(UTC)  | Reason: Not specified
hz dude Offline
#5 Posted: : Friday, 3 October 2008 6:49:48 AM(UTC)
hz dude
Ive seen alot of vns with the same sort of problem and it turned
out to be the harmonic balancer have changed at lest half a dozen
in as many months. maybe as jim5.0 says take the belt off
see how you go cant hert
On The Other Hand Theres Fingers
Edited by user Friday, 3 October 2008 6:51:13 AM(UTC)  | Reason: Not specified
This page was generated in 0.270 seconds.
