Nicho71TPI Offline
#1 Posted : Thursday, 6 January 2011 8:16:13 PM(UTC)
Nicho71TPI
G'day everybody,
I have a VK EFI 6 cyl and Iam after the following bits and pieces, part numbers or suitable alternatives.
1. TVS 104 -Thermostat Vacuum Switch 104 degrees celcius.
Located in the thermostat housing.
2. EGR TVS -
Located in the head above the inlet and exhaust manifolds. Dark brown in colour.
3. Plastic Vacuum T piece.
Located on end of the inlet plenum chamber (fire wall end).
4. TVS 15 - Thermostat Vacuum Switch 15 degrees celcius.
Located on the air intake/ snorkel.
I have been to the following car parts retailers Holden dealer, Repco, Supacheap, Walkers, Barsby Spares(phoned), Rare Spares and Autobarn.
Autobarn have 3 different TVS (1) listed but can not tell me which one is for the VK EFI.
If any one can tell me the part number for the TVS to suit the VK EFI, it would be greatly appreciated.
The plastic vacumm T piece (3) is larger than the T piece from the inlet manifold from a carby model. Ive tried that already.
Any assistance with this information will be greatly appreciated.
Nico.
Iam a fuel injected suicide machine!
#2 Posted : Friday, 7 January 2011 8:29:50 AM(UTC)
all the VK EFI info you need is here http://holdenpaedia.oldholden.com/EFI_VK_3.3
Nicho71TPI Offline
#3 Posted : Friday, 7 January 2011 10:41:07 AM(UTC)
Nicho71TPI
Dave,
Thanks for the link. Ill print off the info from it and add it to my collection. However the link only skims on the information I require for the bits and pieces I require.
Ill keep looking.
Thanks once again Dave.
Nicho
#4 Posted : Friday, 7 January 2011 11:25:07 PM(UTC)
no worries, try posting this over at oldholden.com there's a few guy's over there that know alot about the VK EFI set-up's
link here http://oldholden.com/
#5 Posted : Saturday, 8 January 2011 1:36:22 AM(UTC)
The vacuum T-piece on the VK EFI inlet manifold is different to those on the carby Blue/Black motors. It's not just the number of hose ports either. The EFI fitting has a BSP thread, while all the others are NPT.
Edited by user Saturday, 8 January 2011 1:55:51 AM(UTC)  | Reason: Not specified
