It's been a bit quiet on the forum for the last few days, so why not another quiz ?
We'll go 1 question at a time.
Which Holden was the first to see a Borg Warner diff ?
No prize for the correct answer, just a warm feeling inside.
Byron, you're not allowed to answer.
Dr Terry |
Joined: 30/04/2005(UTC) Posts: 485  ![New Zealand New Zealand]() Was thanked: 16 time(s) in 15 post(s)
life is good in "Wine & Holden Marlborough " |
Do you mean all GMH products (manufactured or assembled or complianced here)?
Do you mean a whole Borg Warner assembly or just gears? |
Australian built or assembled, badged Holden & whole rear axle assembly. Dr Terry |
quote: Originally posted by justgm
VK in NZ . Mark.
VK in Aust had them too, but it is not the correct answer. Dr Terry |
VK in NZ . Mark.
vb commondore in '79. think UC torrie. maybe hb & lc 4cyl torries
VK in NZ . Mark.
VB no, UC no, (VB & UC used GMH Salisbury diffs), early 4 Torries no (they had Vauxhall diffs). Dr Terry |
I honestly don't know. I thought maybe the early 2.78:1 banjo centres were outsourced to Borg Warner, but you say whole axle. Maybe the TX Gemini or the Shuttle? |
Was it the VL Commodore Terry. Regards Tony. Edited by user Friday, 15 June 2012 5:02:27 AM(UTC)
| Reason: Not specified |
What goes around comes around |
That is after VK which had a Borg Warner. TX Gemini and the Shuttle are the only 2 x rear wheel drives I can think of. |
Must have been a Bedford....Jack
Byron, TX Gemini is correct, but didn't you read the rules.
Seriously though, all the Isuzu RWD commercials (Rodeo, Shuttle etc.) had Japanese Isuzu diffs & these vehicles were fully imported anyway.
Dr Terry |
OK, i'll stay out of the next one. Gemini was just a guess though, I couldn't think of any other earlier GMH product that might have been a candidate. Out of interest, who built the early HK 2.78 LSD banjo centres for GMH? Were these Borg Warner or Eaton? |
As I understand it, BW supplied the cone type LSD hemisphere for all Holden-built LSDs. GM-H always made there own cases & gears etc. (Up to VK anyway). The TX/TC Geminis were unique in that they used a whole BW diff assembly, up until the GM-H (UC style) small Salisbury came along for the TD. Dr Terry |
Bedfords are not badged or sold as Holdens. Dr Terry |
Had lunch & ready for the next question Terry ? That last one was a tuff one ! Thanks Mark. |
OK, which Holden series had the first factory electric aerial, available as an option ?
Dr Terry |
I think it was HT. I have a HK and some docs/books for it and am pretty confident you could not get one on HKs but I have seen HT in a brochure somewhere, or maybe a book with a Monaro on it I think, with one mounted on the rear quarter.
HT, correct.
First prize goes to squeak327.
Dr Terry |
What was the first Holden model to get an engine temperature gauge as standard fitting.
Don't count the HD or HR X2 gauge-set, as these were fitted only if you optioned the X2 engine or were available as an option on their own.
Dr Terry |
