Joined: 5/05/2006(UTC) Posts: 92  ![Australia Australia]() Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hi All,
My 308 has developed a miss and is running very rough. I have replaced the Distributor cap, rotor button,plugs and leads leads (it is electronic dizzy) still no change. I would have thought if the cam or lifters were faulty there would be a noise or "chuffing" sound.
Any advice welcome and appreciated.
thanks Dave
I would start with a compression test.
Dr Terry |
Does the coil have 12V to it or is it a proper HEI coil (assuming it is a HEI setup)? |
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Cam shaft could be worn out. Common with cars that have done lots of slow running.
I'm with WBute - the OEM cam lobes aren't too good on old motors that have been stored for a while & used - it's a common failure point. |
Thanks to all who have provided advice. I will run a compression test, but fear it is the camshaft. Thanks again, Dave
Tapping noise for lifters. Chuffing sound for burnt out valve. Missing all together for cam lobe gone/ignition problem. If you pull the rocker covers off and wind it over you will soon see if there is a cam lobe gone and which ones by watching the rocker gear moving/ not moving.
