65ehpv Offline
#1 Posted : Thursday, 7 February 2013 8:32:11 PM(UTC)
65ehpv
wise gentry!
a ubute 308 is a L34
a 253 is L32
stock boring 308 is a L31
a 186s is a L66
what is a 179 X2??
Edited by user Friday, 8 February 2013 8:35:06 AM(UTC)  | Reason: Not specified
Carpe Diem
#2 Posted : Thursday, 7 February 2013 9:43:38 PM(UTC)
253 is also L36
#3 Posted : Thursday, 7 February 2013 11:10:01 PM(UTC)
Hi Guys.
Now here's a topic that might have legs.
These are engine option codes, not compliance codes, but now I'm splitting hairs. One of the problems is that this type of numbering wasn't introduced until the HK series, so there won't be an 'L' code for the 179 X2. From memory the 179 X2 was option no. 578 in the HD series.
The 186S was L66. As wbute has said a 253 V8 will be L32 or L36 depending on the era. There is also L33 which was the low comp 253 V8 in HQ/HJ etc.
John , you should purchase my book, it has every one of these codes listed for each relevant model series.
#4 Posted : Thursday, 7 February 2013 11:45:22 PM(UTC)
L34 isn't just a 308. It is also the code for a 327 in HK (like when 327 was applied to a GTS or a Premier). It was re-used again in LH as it was a vacant code. L30 is 307 in HK and HT, got re-used for 350 in HQ as again it was vacant. I've never been aboe to figure out the low compression 308 code, I hav assumed it is L35 but probably not right.
#5 Posted : Thursday, 7 February 2013 11:48:44 PM(UTC)
Hi Byron.
To my knowledge the lo-comp 308 (prefix BV) in Bedfords was L43. I got it of an old Bedford parts catalogue.
#6 Posted : Friday, 8 February 2013 1:31:16 AM(UTC)
Cool, I couldn't find it in my catalogues. I've got a bandaged finger at the moment, hence my atrocious typing!
65ehpv Offline
#7 Posted : Friday, 8 February 2013 8:36:29 AM(UTC)
65ehpv
Thanks guys, and Terry I might just have to do that.
Can you get it from pit stop?
Carpe Diem
#8 Posted : Friday, 8 February 2013 4:49:40 PM(UTC)
Yes, you can.
http://www.pitstop.net.a...ts/page/query/plu/21948/
Guest (5)
