coupe Offline
#1 Posted : Saturday, 16 March 2013 3:53:42 AM(UTC)
coupe
Is there any one out there that knows what is required to fit a 221 falcon crank to a red 6? Also how much extra cubes does it get you and what other falcon parts a required please, thanks
#2 Posted : Saturday, 16 March 2013 4:38:56 AM(UTC)
I think they were about 230ci with standard bore. I saw Tony Webster in Newcastle building one once. There was some machine work on the crank and clearancing of the block. I think they also welded the crank in a cut and shut to an early red 6 forged crank, can't remember if it was the rear or the snout. From memory it had to be a small main journal block, so 179, or 186. 186 would be the best as they'd have the least overbore.
tripple webers Offline
#3 Posted : Saturday, 16 March 2013 7:54:32 AM(UTC)
tripple webers
Try Pro-stroke i am pretty sure they used to do them, not sure if they still do? You would get 235ci with this crank combo.
FB MAD Offline
#4 Posted : Saturday, 16 March 2013 11:21:11 AM(UTC)
FB MAD
Yep, Pro Stroke and yep 235 cubes. I remember reading a magazine article on Pro Stroke engineering in the '80's, still have the mag " somewhere " ???
I do remember that part of the process was machining and welding on the holden flywheel flange to the 221 Ford crank.
They are still around, here's a link to their stroker kits,
Lookey here :-
http://www.pro-stroke.co...roducts/strokerkits.html
