76HXGTS Offline
#1 Posted : Thursday, 28 November 2013 8:08:54 PM(UTC)
76HXGTS
Hi, Just got the chassis back last night and put it under the body with new rubber mounts.
Can anyone advise where or what to measure to check the alignment, fore and aft position and centreline before tightening it all up?
All the bolts are in, but it appears to be closer to the sill on one side than the other by about 6mm which doesn't look right.
Thanks for any help.
Cocko750 Offline
#2 Posted : Friday, 29 November 2013 6:13:30 AM(UTC)
Cocko750
On my tonner I have left chassis mounts all loose until I align all panels nip them up but not too tight then can be moved enough to get it all lined up
#3 Posted : Friday, 29 November 2013 6:40:50 AM(UTC)
PM me on the weekend to remind me and i'll see if I can find my drawings that show full chassis alignment specs for HQ-HZ chassis. It is a big A3 book that has all diagonal measurments etc in it.
76HXGTS Offline
#4 Posted : Saturday, 30 November 2013 5:24:35 AM(UTC)
76HXGTS
Thanks HK1837,
Message sent.
Cheers.
#5 Posted : Saturday, 30 November 2013 6:19:36 AM(UTC)
Got it. I'll try and scan a page tomorrow. HX sedan I assume?
76HXGTS Offline
#6 Posted : Monday, 2 December 2013 8:23:45 PM(UTC)
76HXGTS
Thanks for that, it gives a whole lot more info than the workshop manual.
Time to get the string lines out!!
Cheers.
Chris Day Offline
#7 Posted : Tuesday, 3 December 2013 8:10:49 PM(UTC)
Chris Day
Mate you can get it straight as you like using measurements but in reality the only way to get these cars right is by gapping it.
Cocko 750 is spot on with his advise
