coupe Offline
#1 Posted : Thursday, 30 January 2014 5:29:46 AM(UTC)
coupe
Hi I am having trouble finding the difference between 6 cyl and v8 column shift powerglide linkages, I cant seem to find any pics and what pieces are different, is it just the crossover under the trans or the whole lot? Is there a link I can find pics? Thanks
#2 Posted : Thursday, 30 January 2014 5:44:35 AM(UTC)
They are totally different.
The pictures that you posted a few days under the title 'Powerglide help', includes the majority of the 6-cyl set-up.
As you can see, the 6-cyl shifter linkage runs under the bell-housing.
The V8 linkage runs across at the rear of the trans, just in front of the rear crossmember.
coupe Offline
#3 Posted : Thursday, 30 January 2014 6:52:01 AM(UTC)
coupe
Does the v8 crossover linkage bolt to the trans pan like a th350 or mount similarly to the 6 cyl one, off the subframe and of a bracket bolted to the passenger side?
