Hi, can someone please let me know what is the normal running temp is for slightly worked 186 motor.. Thanks Edited by user Friday, 14 February 2014 9:40:37 PM(UTC)
| Reason: Not specified
Normal running temp. for a 186 would be 80-85 C.
A 'slightly worked' one would just run hotter at idle unless you've increased the fan & radiator size to cope.
Dr Terry |
many thanks this one is running around a 100
First thing to do is get the temp. gauge reading verified. A hand-held infra-red thermometer is a common mechanics tool these days. It's quick, accurate & easy to use.
More often than not the temp. gauge is telling fibs.
Dr Terry |
Many Thanks I will follow this up
