Oldolden Offline
#1 Posted : Saturday, 30 August 2014 3:56:36 AM(UTC)
Oldolden
Hi all, the hk t g boot emblem, are they installed using speed nuts if so what size are they, or are they the push in type badge mounting inserts?
Cheers Rob
gm5735 Offline
#2 Posted : Sunday, 31 August 2014 8:37:24 PM(UTC)
gm5735
Hi. The model badge on the boot is held with pressed metal speed nuts. The letters on van and wagon tailgates are held with tubular push in clips.
I don't have any of the correct nuts around to help you with the sizing unfortunately, but I can tell you they different to the speed nuts used to hold the heater halves together.
Oldolden Offline
#3 Posted : Monday, 1 September 2014 12:20:22 AM(UTC)
Oldolden
It's the emblem like the HK grille emblem but is horizontal , fits on the top edge middle of the boot lid, the speed nuts appear to be 1\8 inch diam and 5\16 inch sae socket as I took one from the side rear quarter mould and tried it, perfect fit.
Have ordered some from rares.
Appreciate your help?
Rob
