coupe Offline
#1 Posted : Sunday, 19 July 2015 5:29:44 AM(UTC)
coupe
Can i please get some technical help on this matter. I have a hk v8 disk brake front end. One caliper says girling the other nothing. The disks are 5/8 inch thick and there is no spacer in between the caliper halves like the later ht hg girlock calipers. I thought all girling hk calipers used a half inch disk not 5/8 disk.
#2 Posted : Sunday, 19 July 2015 6:28:45 AM(UTC)
Are they XT discs and possibly calipers?
coupe Offline
#3 Posted : Sunday, 19 July 2015 7:15:06 PM(UTC)
coupe
Im not sure mate. Im selling the front end and just want to make sure they're not off something gts
#4 Posted : Sunday, 19 July 2015 7:20:47 PM(UTC)
GTS are the same as all others with disc brakes in the same series in HK-HG. The only odd one out is HT GTS350 which has the HG's rotors and calipers with spacers. A common mod for the day if you put an XW-XY 9" in a HK-HG was to put XT rotors on as it was an easy way to change stud pattern to Ford on the front. I think you just used HG calipers with them but possibly XT.
coupe Offline
#5 Posted : Sunday, 19 July 2015 7:33:16 PM(UTC)
coupe
Cheers thanks mate. Rims are hk so i dont know whats going on.
