View Thanks
nineteenfortyeight Offline
#1 Posted : Monday, 7 May 2018 6:01:58 PM(UTC)
nineteenfortyeight
Hi all. I pulled the motor and box out of my Van this morning and had trouble getting all the gear box cross member bolts out. 2 had rounded heads and were frozen solid. One of those broke off and the other 2 came out easily. I tried to get the bolts out of the extensions and they won't move either. They look like 'special' bolts with a big head and smaller nut and washer. The nuts came off easily. I haven't had a gas axe for more than 25 years so don't have anything to heat it before trying again. Any suggestions? I managed to get the motor and box out by removing the mount first and only just slipping it all out leaving the cross member in place. I borrowed the engine lifter from my neighbor after helping him fit a 6 cylinder motor into his $300 XE Fairmont Wagon and wanted to give it back ASAP.
48 215
KBM Offline
#2 Posted : Monday, 7 May 2018 7:00:08 PM(UTC)
KBM
sounds like someone has put wrong bolts in. you used to put in what ever you had to fit not thinking somebody was actually going to remove them 20+ years later. try putting a wooden block between the extension and the floor and belt the fuck out of it with a drift bolt. someone on here will probably have a more sensible solution but I always say if it don't move hit it with the biggest hammer you've got
#3 Posted : Tuesday, 8 May 2018 10:29:56 AM(UTC)
nineteenfortyeight
Thanks KBM. I'll have another play with it today after spraying some inox on it all.
48 215
