tidyVan Offline
#1 Posted : Saturday, 13 January 2024 3:31:46 PM(UTC)
tidyVan
I found this conversation from a while ago and was wondering if anyone might know the exact part for the T-Piece?
https://www.fastlane.com...h-for-308.aspx#post73426
Today I learnt that the VDO 360.005 Oil Pressure Sender I have wont work for the 304 ECU so I need to get a suitable one, and I have a mechanical Autometer gauge for visuals (https://www.vpw.com.au/parts/AMT-3321). The engine wont be in the car when started for running in, so that means no dashboard. :-) Plus the dashboard is still in a cupboard somewhere.
All tips or pointers are appreciated.
#2 Posted : Saturday, 13 January 2024 5:41:32 PM(UTC)
Old red 6 intake brass T works. See photos. This is a VP 5.0L going into a HZ cab-chassis with new J&P oil pump.
This is basically a made up one which you can do with brass bits from a gas shop. Here is a red 6 item that will do the same job:
https://www.ebay.com.au/itm/255957474510
Edited by user Saturday, 13 January 2024 5:48:09 PM(UTC)  | Reason: Not specified
tidyVan on 13/01/2024(UTC)
tidyVan Offline
#3 Posted : Saturday, 13 January 2024 6:31:28 PM(UTC)
tidyVan
Thank you HK1837 for sending the pics and the ebay link. :-)
I found this part which looks like it might be the same thing.
https://confitaustralia....is-is-npt-thread-not-bsp
The URL has 1/8 but the description is 1/4 NPT. I guess it can't hurt to try it.
