cfm
#1 Posted : Wednesday, 28 September 2005 5:00:19 AM(UTC)
Hi guys,
just read this on OH.com, so using the formula 186x4500/3456 (cid x rpm/3456) to find the required CFM makes my 186 want a 242ish cfm carby. my Q is what is the CFM of a single barrel stromberg, + a ww 2 barrel?
Elton.
www.68hk.oldholden.com
there are no stupid questions, only stupid people
#2 Posted : Wednesday, 28 September 2005 7:20:14 AM(UTC)
You can easily work the same formula out yourself by:
Converting a cubic inch into a cubic foot = 1/12 x 1/12 x 1/12 = 1/1728.
Now one rpm of an engine will draw in half of the engine's swept volume (cubic inches) as it is a 4-stroke (another way to s
#3 Posted : Wednesday, 28 September 2005 7:44:27 AM(UTC)
thanks Byron, after reading the ww stromberg identification thread the other day i haven't yet looked for a part number on mine so i can tell which model/engine it's from, i will tomorrow...I plan to use the ww + X2 headers on a stock 186/powerglide at fi
#4 Posted : Thursday, 29 September 2005 5:40:19 AM(UTC)
if anything, go a bit bigger, rather than smaller.
even a 300cfm.
you will lose a bit of responsiveness, nut with correct jets, it will go well, and leave room for further improvements like exhausts, cams, rebuilds etc.
DO NOT WRITE BELOW THIS LINE
