I am going to look at LX SS hatch tommorow what Numbers should i look for the guy said eng tag is L31 gearbox is M21 what other things would i look for might be A9X any help would be appreciated cheers
the tag reads as a 308 4spd. A9X has HQ-WB stud pattern model number on the plate for an SS should read 8VD77 . (A9X) is an option code that would appear after the model number if that is what it is. If the number reads 8VC77 it is a SL hatchback 6/8
Thanks: 1 times Was thanked: 607 time(s) in 574 post(s)
AFAIK A9X never appeared on the BODY plate. An A9X was only an option on an LX SS, and as all of these were built in Melbourne there is option codes on the plates. Email me the VIN number and I'll look at what I have. I have a list somewhere of all A9X VI |
thanks guys very helpful cheers
Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
Hi Guys.
Byron, wasn't the A9X option also available on the LX SL/R 5000.
Also was that a typo, you didn't mean to say that Melbourne cars DID have A9X on the plate did you.
Dr Terry |
Have some more numbers bought it today LX8VD77 Body527172M Trim 1887-60B Paint 568-15950 Eng L31 TransM21 I Know motor and trans can someone help with trim and paint cheers
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
Only part I can help you with is the paint is called "Chamois"
(If it was a commodore though.....)
A lot of people aim to achieve nothing in life - and have amazing |
quote: Originally posted by Dr Terry
Hi Guys.
Also was |
Thanks guys where would the chassis number be stamped cheers
Near the canister RH side of engine bay.
If it's not there, because of panel replacement etc it is repeated on the compliance plate. That's the plate with the date on it.
Dr Terry. |
it was there but someone had welded it in not very well dogy bastards very disapointed cheers
If you want to restore the car to original, and you are OK with restamping a number (by OK I mean prepared to accept any legal or moral issues) then this is how to do it on an LH/LX, also assuming you have access to the correct stamps:
Unpick the trian |
were they original rivets holding the compliance plates on? I mean there are 2 things..it could either be original but have crash damage....or someone has rebirthed it.
