Does any one know if the VK Commadore Diff will fit into a WB ute. Just a thought
THANKS TITMAR
The whole back axle or just the diff? The axle won't fit too narrow and you have to modify the spring mounts. A VN onwards will be almost perfect fit but will still need the mounts modified.
The whole back axle or just the diff? The axle wont fit too narrow and you have to modify the spring mounts. A VN onwards will be almost perfect fit but will still need the mounts modified.
Jus give me ur email and il send u the diagram 2nite
The hole think ,just thought since the one in the ute is u/s I thought well I have one can I use it. I didnt know about the VN,Did they come out with disc ass ends .
thanks Titmar
titmar: I've just finished this conversion in my LC Torana, goes great. this might come in handy for the fuel pump relay. http://www.oldholdens.co...sion/efirelay-wiring.jpgSammy's site is great for info http://www.oldholdens.cEdited by user Friday, 25 August 2006 9:23:31 AM(UTC)
| Reason: Not specified
titmar: Ive just finished this conversion in my LC Torana, goes great. this might come in handy for the fuel pump relay. http://www.oldholdens.co...sion/efirelay-wiring.jpgSammys site is great for info http://www.oldholdens.comEdited by user Friday, 25 August 2006 9:23:31 AM(UTC)
The VN onwards all had disk rears. the width disk to disk is within a smick of the HQ-WB.
Gday Can any body tell me the best header to put on my 3.3 EFI motor to get the best out of the motor .
Thank Titmar
use the stainless steel EFI stockie they are as good as most and cheap.
Gday mates I was talking to some mates about my ute and they said about puting in a surge tank , do I need one or not.
Thanks Titmar
It is a very good idea, but not absolutely necessary. Say a bit like an oil cooler on an auto transmission. The idea of a swirl pot is to ensure you always have petrol in the pump as it is how the pump is lubricated. One will cost you about $125 from Amer |
For ease it probably best to put in a surge tank and just use a lift pump then the efi. its not as neat but can be done easily. a guy on ebay makes custom surge tanks for a reasonable price to your specs. Geting an efi tank to fit is not fun but cvan be d
Hello its me again, just a quick question do I have to drill the dip stick hole out in the black motor or is there a plug in it.
Thanks Titmar
The plug kmocks out but you have to reach it by taking the sump off and using a long rod to get a it. The dipstick tube from the earlier motor will have to be fitted, I had real problems getting it to seal it kept leaking oil, also it has to go in a part
Thanks johnperth I will do that tomorrow .
Thanks Titmar
Hello out thier I would like to know if a vn disc ass end fit a wb ute or is it to narrow.
always remember BROCKIE 05 Titmar
VN onwards fit almost perfectly but of course you have to modify the brackets etc and I believe some messing about with the handbrake setup.
Hello Again , Question I have just been offered a 5 speed gearbox out of a vn wagon would this be better than a supra 5 or sould I stick with the supra 5
Thanks Titmar
Stick with the supra box.
___________________ Why are you reading this, you should be looking up there^^ |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
