Mr.Jones Offline
#1 Posted : Friday, 18 August 2006 9:12:39 PM(UTC)
Mr.Jones
My brothers vk is a 12/84 build with L31 on the plate and QT eng no. was wondering if this engine gets any of the 'good' bits or was it only the later 304's
VK8VK19 - 134
xxxxxxxx
3054 64x
1F086 -D =Red
Was also wondering whether you could get a V8 without have 1/2/334 pack or was that mandatory when you ticked the V8 box. Thanks hope someone can clarify
Leroy
Voltaire
#2 Posted : Friday, 18 August 2006 9:37:38 PM(UTC)
It was a factory 308 4 speed, which usually got the good engine bits, but as it now has a QT block, I'd say that's all gone.
I'll clarify the packs a bit later when I have time.
______________________________________________________
Mr.Jones Offline
#3 Posted : Friday, 18 August 2006 9:50:59 PM(UTC)
Mr.Jones
Thanks for the prompt reply commodorenut AFAIK it still has the original engine (car has been in the family for 12 or so years)
Voltaire
#4 Posted : Friday, 18 August 2006 10:38:53 PM(UTC)
Hi Guys.
As Mick says the QT is not the original block.
The QT was the 308 used in HQ/HJ/HX/HZ (exc. Statesmans) prior to 1 Sept '78.
A Commodore 308 would be either VT or VZ.
Mr.Jones Offline
#5 Posted : Friday, 18 August 2006 10:44:58 PM(UTC)
Mr.Jones
Sorry guys my bad was thinking of the other block I have in shed eng no.is VT49xxxx
Cheers Leroy
Voltaire
#6 Posted : Saturday, 19 August 2006 3:00:49 AM(UTC)
VT49... block number is spot on for late 84.
The 134 pack is explained as follows:
1st digit is the trim level (1 = SL/exec)
2nd digit is the engine (3 = 5L V8)
3rd digit is the gearbox (4 = 4 speed manual).
This isn't the be-all & end-all thou
