My brothers vk is a 12/84 build with L31 on the plate and QT eng no. was wondering if this engine gets any of the 'good' bits or was it only the later 304's VK8VK19 - 134 xxxxxxxx 3054 64x 1F086 -D =Red Was also wondering whether you could get a V8 without have 1/2/334 pack or was that mandatory when you ticked the V8 box. Thanks hope someone can clarify
Leroy |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
It was a factory 308 4 speed, which usually got the good engine bits, but as it now has a QT block, I'd say that's all gone.
I'll clarify the packs a bit later when I have time.
Mick ______________________________________________________ |
Thanks for the prompt reply commodorenut AFAIK it still has the original engine (car has been in the family for 12 or so years) |
Hi Guys.
As Mick says the QT is not the original block.
The QT was the 308 used in HQ/HJ/HX/HZ (exc. Statesmans) prior to 1 Sept '78.
A Commodore 308 would be either VT or VZ.
Dr Terry |
Sorry guys my bad was thinking of the other block I have in shed eng no.is VT49xxxx
Cheers Leroy |
VT49... block number is spot on for late 84.
The 134 pack is explained as follows:
1st digit is the trim level (1 = SL/exec) 2nd digit is the engine (3 = 5L V8) 3rd digit is the gearbox (4 = 4 speed manual).
This isn't the be-all & end-all thou |
