Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Looks like one to me. 18V trim is Kingswood and Sandman trim in a HX, and a 1950kg GVW gives you about a 95% chance also. Its a very early example too. |
Hi Byron - found another ute for your register. Details e-mailed to you.
Hi there pls check this out/HX8WM70 /BODY 204258-A /TRIM 2214-65A /PAINT 568-15991 /8MTORFL355319X /L32 M40 GU4 /O8/76 AHX 05913A / GVW 1950 SEATING 2.I BOUGHT THIS VAN YEARS AGO ,FACTORY BLACK HEAPS OF EXTRAS FITTED ,HAD SILVER STRIPING . WHAT CAN YOU TELL ME ANY INFO APPRECIATED
An original Tuxedo black with silver stripes Sandman. What a find! Pity its only a 253, but will actually be rarer than a 308. The 65A (Sienna) trim code on a HX8WM70/80 almost guarantees a Sandman. It should also have:
GTS dash and steering wheel, GTS wheels, full length headlining. |
Hi again its got all those plus a few extra factory options trying to locate bloke i bought it off.dont know about stripes thou have you a phone # or address to write to.
email didnt come thru.it is [email protected] pls try again (in lower case??)anyhow tracked down bloke i bought it off/he only remembers buying it from a caryard in w.a with silver stripes on it.
email came thru but wont accept attachment to it.so couldnt see what you sent.if you want i can email you my address & phone # ?
Hi byron, ive spoken to you before about my hx sandman panelvan, im just wondering if you might know whether the hx had the option of twin headlights or only singles? thanks
Only singles. If it looks and smells like a Sandman and has a twin front it will be a BO6 ambulance pack. |
unreal site! anyone know of a part number/trim code number almanac on the web?
hey byron, got a few questions for u and may be able to help with some answers?i have a hz panelvan,sandman? it has striping on it - dark and light blue with purple ? hard to see.the dark and light blue striping run down the side and cant make out what the purple? is {some design}the colour of the van is atlantis blue but it has been resprayed well sort of. a bodgy job. cheers
Its probably DX5 (plum, purple, dark blue) or DY6 (blue/purple) stripes. HOWEVER, Atlantis blue is paint code 1934 and according to the ordering procedure you could only get DY4 with that colour. BUT the stripe colours are somewhat ambiguous as you can see on my website. I actually guessed the codes vs colours for three codes so they could be around the wrong way. Or someone has bought the wrong stripes for your van when resprayed. With the colours vs codes on my website I think the first lot listed in the production option availability are incorrect as they are the same as HX, and someone forgot to fix them in the HZ manual. Id be more believing the 7/78 ordering procedure info and the 1980 revison of the parts text catalogue. |
thanks byron,will back in touch later cheers again
im back already.byron on my tyre placard # it has 9946865.this seems to be 1 digit out from looking on sandman owners website.number there is 9946866.does this make any difference to being original etc.thanks again
Be careful of the info on that website as its not all there or not all correct. But the tyre placard quoted is correct for a HZ XX7 Sandman, with the XU3 version being 92001123. Dont panic if yours is different as its not hard to change a glovebox lid. Check for all of the other Sandman telltales. My website has details on it to help you with Sandman identification. The third icon on one of my posts will get you there. |
