trying to find out what make of gearbox came out in the 1969 ht premier/
unless someone has changed it?...should be an opel... |
Or a powerglide...
Cheers...Dave
Joined: 1/03/2005(UTC) Posts: 241  ![Australia Australia]() Thanks: 3 times
Bought a HT Prem in the early 90's had a 253 4 speed Saginaw...was factory ..could tell by the floor pan. Cheers Paul |
Jesse Jesse Jesse, you've not got a sense of humour! |
Hi Guys.
If your HT Premier is a 6 cyl it will most likely be an M20 Opel 4 speed, although the M21/M21 Saginaws were also an option. If it's a 253 or 308 V8 then it's an M21 Saginaw.
Dr Terry |
Hi Guys.
That should read M21 or M22 Saginaw as the 6 cyl alternative.
Dr Terry. |
Bugger...I missed the bit about 4 speed in the post's header...that's why I posted the Glide comment above...
It wasn't a good weekend...looks like the mrs has Malaria...
Cheers...Dave
sorry to intrude in you thread but is a m22 a saginaw zac
Nothing beats cubic inches !!!
Only in the HK/T/G models.
In the HQ and later ones, the M22 is an Aussie box.
Cheers...Dave
Wasnt the M22 aussie 4 speed in the one tonners? 1st and 2nd gear real close ratio |
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Yes, but 1st and 2nd WIDE not close. 3.74:1 1st. Optional on other models too eg HQ coupe.
In HK-HG M20 is the Opel box, M21 is the V8 Saginaw close ratio box and M22 is the wide ratio Saginaw. Holden Recycled the option codes when they were obsolete. |
Hi Guys.
The Mxx numbers are only RPO (Regular Production Option) numbers used by the sales dept. They do not refer to only one type of box.
In the HK/T/G & early LC Torana series M20 = Opel & M21 & M22 = Saginaw.
In HQ-WB Series & Torana (Mid |
Also the 4 speed in a TA torana 1300.
warren
