Evil Homer Offline
#1 Posted : Monday, 9 January 2006 7:07:35 AM(UTC)
Evil Homer
trying to find out what make of gearbox came out in the 1969 ht premier/
classic oz wreck Offline
#2 Posted : Monday, 9 January 2006 8:36:15 AM(UTC)
classic oz wreck
unless someone has changed it?...should be an opel...
www.classicozwreck.com.au
#3 Posted : Monday, 9 January 2006 9:31:29 AM(UTC)
Or a powerglide...
Cheers...Dave
Bluez Offline
#4 Posted : Monday, 9 January 2006 10:27:34 AM(UTC)
Bluez
Bought a HT Prem in the early 90's had a 253 4 speed Saginaw...was factory ..could tell by the floor pan.
Paul
Jesse Jesse Jesse, you've not got a sense of humour!
#5 Posted : Monday, 9 January 2006 6:08:01 PM(UTC)
Hi Guys.
If your HT Premier is a 6 cyl it will most likely be an M20 Opel 4 speed, although the M21/M21 Saginaws were also an option. If it's a 253 or 308 V8 then it's an M21 Saginaw.
#6 Posted : Monday, 9 January 2006 6:10:41 PM(UTC)
Hi Guys.
That should read M21 or M22 Saginaw as the 6 cyl alternative.
Dr Terry.
#7 Posted: : Monday, 9 January 2006 10:15:15 PM(UTC)
Bugger...I missed the bit about 4 speed in the post's header...that's why I posted the Glide comment above...
It wasn't a good weekend...looks like the mrs has Malaria...
Cheers...Dave
#8 Posted : Tuesday, 10 January 2006 7:23:32 AM(UTC)
sorry to intrude in you thread but is a m22 a saginaw
zac
Nothing beats cubic inches !!!
#9 Posted : Tuesday, 10 January 2006 9:33:27 AM(UTC)
Only in the HK/T/G models.
In the HQ and later ones, the M22 is an Aussie box.
Cheers...Dave
Bluez Offline
#10 Posted : Tuesday, 10 January 2006 9:53:07 AM(UTC)
Bluez
Wasnt the M22 aussie 4 speed in the one tonners? 1st and 2nd gear real close ratio
#11 Posted : Tuesday, 10 January 2006 6:06:40 PM(UTC)
Yes, but 1st and 2nd WIDE not close. 3.74:1 1st. Optional on other models too eg HQ coupe.
In HK-HG M20 is the Opel box, M21 is the V8 Saginaw close ratio box and M22 is the wide ratio Saginaw. Holden Recycled the option codes when they were obsolete.
#12 Posted : Tuesday, 10 January 2006 6:15:16 PM(UTC)
Hi Guys.
The Mxx numbers are only RPO (Regular Production Option) numbers used by the sales dept. They do not refer to only one type of box.
In the HK/T/G & early LC Torana series M20 = Opel & M21 & M22 = Saginaw.
In HQ-WB Series & Torana (Mid
#13 Posted : Wednesday, 11 January 2006 1:50:20 AM(UTC)
Also the 4 speed in a TA torana 1300.
warren
This page was generated in 0.120 seconds.
