clearway Offline
#1 Posted : Thursday, 3 January 2008 7:22:03 PM(UTC)
clearway
went to see a ht monaro to buy the other day
the complinace plate had HT 46514M 6-70
But the firewall had stamped HT 48514M , they did not match
the car looks like the engine has never been out of the car
would this be a typo mistake when stamping the car ?
is this common , should these number match ....
" Smokem Baby "
" Smokem Baby "
#2 Posted : Thursday, 3 January 2008 7:33:32 PM(UTC)
Yes they should match, and it's unlikely for someone to get that many digits right when doing a body swap so unless you've read it wrong it must be a mistake. I'd check it again though as the die for the 8 stamp did wear out in Pagewood as i've seen heaps
#3 Posted : Thursday, 3 January 2008 7:33:32 PM(UTC)
Yes they should match, and its unlikely for someone to get that many digits right when doing a body swap so unless youve read it wrong it must be a mistake. Id check it again though as the die for the 8 stamp did wear out in Pagewood as ive seen heaps of
clearway Offline
#4 Posted : Thursday, 3 January 2008 9:08:29 PM(UTC)
clearway
ok has there ever been cars that have had a numbers stamped wrong
from the factory typo .....
" Smokem Baby "
" Smokem Baby "
#5 Posted : Thursday, 3 January 2008 10:56:57 PM(UTC)
yes there was a HQ statesman with a build date of 2-1984, stamped into the complience plate, for sale some time ago on ebay...
Stat Man Offline
#6 Posted : Friday, 4 January 2008 12:45:41 AM(UTC)
Stat Man
I have a HQ Coupe that has a stamped firewall that doesn't match. I can assure you the body I.D tag has never been removed from the car yet the plate has 45 -S and the firewall has 29 - S.
What is the firewall stamp anyway? I was told it has no referenc
Stat Man Offline
#7 Posted : Friday, 4 January 2008 12:45:41 AM(UTC)
Stat Man
I have a HQ Coupe that has a stamped firewall that doesnt match. I can assure you the body I.D tag has never been removed from the car yet the plate has 45 -S and the firewall has 29 - S.
What is the firewall stamp anyway? I was told it has no reference
#8 Posted : Friday, 4 January 2008 2:25:49 AM(UTC)
adam PERTH Offline
#9 Posted : Friday, 4 January 2008 2:27:22 AM(UTC)
adam PERTH
i wrecked a VB commodore years ago, made in 1999!, not 1979
A1 Bogan.
clearway Offline
#10 Posted : Friday, 4 January 2008 4:25:41 AM(UTC)
clearway
the firewall is stamped 8 but the tag says 6
i would lean towards a typo on this from factory
being m dandenong they stamped on digit wrong
" Smokem Baby "
" Smokem Baby "
#11 Posted : Friday, 4 January 2008 5:40:12 AM(UTC)
#12 Posted : Friday, 4 January 2008 5:40:12 AM(UTC)
Stat Man Offline
#13 Posted : Friday, 4 January 2008 7:19:31 AM(UTC)
Stat Man
Ok Byron, what if I told you that my HQ coupe, on very thorough inspection doesnt have a chassis number on either chassis rail and definitely nothing near the steering box, nor does it have an ADR plate fitted. This one was intended for export.
Stat Man Offline
#14 Posted : Friday, 4 January 2008 7:19:31 AM(UTC)
Stat Man
Ok Byron, what if I told you that my HQ coupe, on very thorough inspection doesn't have a chassis number on either chassis rail and definitely nothing near the steering box, nor does it have an ADR plate fitted. This one was intended for export.
clearway Offline
#15 Posted : Friday, 4 January 2008 7:35:10 AM(UTC)
clearway
byron where should the numbers be on a hq gts monaro
i have seen on the rhs chassis rail , but did all of them have
numbers stamped on the firewall , meaning 2 times or was it one
of the 2 positions you mentoined in your post , is this what they cal
" Smokem Baby "
#16 Posted : Friday, 4 January 2008 7:36:23 PM(UTC)
Stat man - export HQ's had no chassis number on the chassis rail, nor an ADR plate. If it was a Chev engine you'll also find it had no Australian component in the engine number. But, the number on the firewall still means nothing. It's normally close to t
#17 Posted : Friday, 4 January 2008 7:36:23 PM(UTC)
Stat man - export HQs had no chassis number on the chassis rail, nor an ADR plate. If it was a Chev engine youll also find it had no Australian component in the engine number. But, the number on the firewall still means nothing. Its normally close to the
clearway Offline
#18 Posted : Saturday, 5 January 2008 6:58:34 AM(UTC)
clearway
my hq has not no numbers on the firewall it has on the rhs rail
that matches the body plate number , unless i have not looked well
enough i will invistigate and get back to you obviously the vin tells you wher the car was built in this case Pagewood .
" Smokem Baby "
