went to see a ht monaro to buy the other day the complinace plate had HT 46514M 6-70 But the firewall had stamped HT 48514M , they did not match the car looks like the engine has never been out of the car would this be a typo mistake when stamping the car ? is this common , should these number match ....
" Smokem Baby " |
" Smokem Baby " |
Yes they should match, and it's unlikely for someone to get that many digits right when doing a body swap so unless you've read it wrong it must be a mistake. I'd check it again though as the die for the 8 stamp did wear out in Pagewood as i've seen heaps |
Yes they should match, and its unlikely for someone to get that many digits right when doing a body swap so unless youve read it wrong it must be a mistake. Id check it again though as the die for the 8 stamp did wear out in Pagewood as ive seen heaps of |
ok has there ever been cars that have had a numbers stamped wrong from the factory typo .....
" Smokem Baby " |
" Smokem Baby " |
yes there was a HQ statesman with a build date of 2-1984, stamped into the complience plate, for sale some time ago on ebay...
HOLDEN The Great Way to Move |
I have a HQ Coupe that has a stamped firewall that doesn't match. I can assure you the body I.D tag has never been removed from the car yet the plate has 45 -S and the firewall has 29 - S. What is the firewall stamp anyway? I was told it has no referenc
I have a HQ Coupe that has a stamped firewall that doesnt match. I can assure you the body I.D tag has never been removed from the car yet the plate has 45 -S and the firewall has 29 - S. What is the firewall stamp anyway? I was told it has no reference
quote: Originally posted by clearway
ok has there ever been cars that have had a numbers stamped wrong from the factory typ |
i wrecked a VB commodore years ago, made in 1999!, not 1979
A1 Bogan. |
the firewall is stamped 8 but the tag says 6 i would lean towards a typo on this from factory being m dandenong they stamped on digit wrong
" Smokem Baby " |
" Smokem Baby " |
quote: Originally posted by Stat Man
I have a HQ Coupe that has a stamped firewall that doesn't match. I can assure you the bo |
I have a HQ Coupe that has a stamped firewall that doesnt match. I can assure you the bod |
Ok Byron, what if I told you that my HQ coupe, on very thorough inspection doesnt have a chassis number on either chassis rail and definitely nothing near the steering box, nor does it have an ADR plate fitted. This one was intended for export.
Ok Byron, what if I told you that my HQ coupe, on very thorough inspection doesn't have a chassis number on either chassis rail and definitely nothing near the steering box, nor does it have an ADR plate fitted. This one was intended for export.
byron where should the numbers be on a hq gts monaro i have seen on the rhs chassis rail , but did all of them have numbers stamped on the firewall , meaning 2 times or was it one of the 2 positions you mentoined in your post , is this what they cal |
" Smokem Baby " |
Stat man - export HQ's had no chassis number on the chassis rail, nor an ADR plate. If it was a Chev engine you'll also find it had no Australian component in the engine number. But, the number on the firewall still means nothing. It's normally close to t |
Stat man - export HQs had no chassis number on the chassis rail, nor an ADR plate. If it was a Chev engine youll also find it had no Australian component in the engine number. But, the number on the firewall still means nothing. Its normally close to the |
my hq has not no numbers on the firewall it has on the rhs rail that matches the body plate number , unless i have not looked well enough i will invistigate and get back to you obviously the vin tells you wher the car was built in this case Pagewood . |
" Smokem Baby " |
