picardy Offline
#1 Posted : Saturday, 12 January 2008 6:17:05 AM(UTC)
picardy
Hi
I just purchased a HK its been sitting in the shed for about 24yrs and in pretty good nic ? the compliance and body numbers match but how do I verify the engine number, should they be the same as one of the compliance plates.
Scott
#2 Posted : Saturday, 12 January 2008 6:29:00 AM(UTC)
engine number wont match the plates, give the engine number to Byron he should be able to tell if its close to the build date.
Edited by user Saturday, 12 January 2008 6:29:34 AM(UTC)  | Reason: Not specified
#3 Posted : Saturday, 12 January 2008 6:37:58 AM(UTC)
Was thanked: 611 time(s) in 578 post(s)
HK won't have a comliance plate and BODY and VIN plates never match in HK.
#4 Posted : Saturday, 12 January 2008 6:37:58 AM(UTC)
HK wont have a comliance plate and BODY and VIN plates never match in HK.
picardy Offline
#5 Posted : Saturday, 12 January 2008 6:40:58 AM(UTC)
picardy
The engine number is 186s101920.
Scott
picardy Offline
#6 Posted : Saturday, 12 January 2008 6:49:35 AM(UTC)
picardy
Ok thanks, so the engine numbers state what year they were produced that makes them compatable
Scott
#7 Posted : Saturday, 12 January 2008 5:45:54 PM(UTC)
No, engine numbers are sequential. The way to work out if the engine is close to right is to compare it to known matching numbers cars (by log books). There are no tag or body numbers anywhere on a HK that tell you when it was built. The way to pick them
#8 Posted : Saturday, 12 January 2008 6:49:47 PM(UTC)
Thanks a lot for the info, what would be your advice on the engine I was thinking I will put a turbo 6 in or should I just go straight to a V8. With the 6 I can leave all the running gear and still have a little power but nothing over the hill. I can send
#9 Posted : Saturday, 12 January 2008 11:25:36 PM(UTC)
Send me the ID plate details and ill tell you all there is to know about it. A V8 will be cheaper and easier also.
#10 Posted : Saturday, 12 January 2008 11:25:36 PM(UTC)
Send me the ID plate details and i'll tell you all there is to know about it. A V8 will be cheaper and easier also.
picardy Offline
#11 Posted : Sunday, 13 January 2008 12:41:20 AM(UTC)
picardy
Her are the numbers I have off the vehicle, Im new to this I dont know how to attach the pictures. Body HK89737-106-A / Trim 1152-18 Y / Paint 568-1285. 80737KL116695 stamp on firewall HK 34926 A.
Thanks vry much appreciated if you would like a pic I can
Scott
JBM Offline
#12 Posted : Sunday, 13 January 2008 5:14:14 AM(UTC)
JBM
568-1285 is Picardy Red (what a shock, just kidding) 18Y is Buckskin. The VIN, Firewall and Body Nos are for an Adelaide car.
Is your car 2 tone?
James
You only have to be in front at the e
Edited by user Sunday, 13 January 2008 5:17:05 AM(UTC)  | Reason: Not specified
picardy Offline
#13 Posted : Sunday, 13 January 2008 7:19:32 AM(UTC)
picardy
No the car is just red with bonnet boot stripes and stripes along the lower Rh/Lh side.
Scott
#14 Posted : Sunday, 13 January 2008 6:50:28 PM(UTC)
18Y is Parchment and black trim. Everything else appears to be in order, but will check further.
picardy Offline
#15 Posted : Sunday, 13 January 2008 7:11:25 PM(UTC)
picardy
Thanks very much for the help Byron, I will be taking your advice and putting a V8 in the car maybe just a 307 if anything available could let me know.
Scott
Scott
#16 Posted : Sunday, 13 January 2008 10:33:10 PM(UTC)
A 307 and TH350 will go in without damaging the originality of the car ie fit without cutting holes. Make sure you keep the original running gear complete so it can be changed back. Use a HT/G trimatic shifter for the TH350. You can also use a Chev powerg
picardy Offline
#17 Posted : Monday, 14 January 2008 6:32:22 AM(UTC)
picardy
Ok thanks what diff should I use or the one in it will be ok.
Scott
Scott
#18 Posted : Monday, 14 January 2008 4:14:25 PM(UTC)
The cheapest way out is probably a 9". Just get one made with Holden brakes on the end. Have a think about whether you want to keep the HK brakes or swap to HQ-WB. The diff will be able to be done in either. HQ-WB discs and calipers are a bolt on at the f
picardy Offline
#19 Posted : Tuesday, 15 January 2008 3:46:54 AM(UTC)
picardy
I have just been offered a running 327 with a th350 for $3000
Scott
Scott
#20 Posted : Tuesday, 15 January 2008 4:57:59 AM(UTC)
Your body number should be 601-A. Other than that all checks up OK.
This page was generated in 0.098 seconds.
