Hi guys, i know its a ford box, but it's strong, and it's cheap. so tell me guys, will it fit in a VK commodore trans tunnel? clutch and bellhousing are not a problem.
cheers Alex
Hi Boom, I think that the gearbox fits in the tunnel fine but I am not so sure on the shifter/linkages. Have you considered fitting a single rail gearbox from a Cortina as these can be bought very cheaply. Same bellhousing and clutch, speedo cable etc.
needs to handle huge amounts of power/thrashing so, i don't think i'll be going single rail. but thanks for the tip.
i'm going custom console, so i don't mind cutting another hole for the new linkages.
BTW does anybody actually know how much power a
needs to handle huge amounts of power/thrashing so, i dont think ill be going single rail. but thanks for the tip.
im going custom console, so i dont mind cutting another hole for the new linkages.
BTW does anybody actually know how much power a top
My mates HK used to bust them regularly with about 400hp (350 Chev). He ended up going back to a Muncie and has never blown one of those.
_______________________________________________________ If we all had the same (good) taste, who would buy all th |
My mate's HK used to bust them regularly with about 400hp (350 Chev). He ended up going back to a Muncie and has never blown one of those.
_______________________________________________________ If we all had the same (good) taste, who would buy all t |
yeah? how much are muncies going for atm? will it fit in the tunnel?
a muncie would be easier, as i can use the saginaw bellhousing as you previously mentioned.
If nissan motorsport is nismo, then doesnt that make honda motors
Probably close to a good toploader in cost. You should find one for $750, except for the original HQ style which are worth good money because they belong to HQ GTS 350's.
_______________________________________________________ If we all had the same ( |
Probably close to a good toploader in cost. You should find one for $750, except for the original HQ style which are worth good money because they belong to HQ GTS 350s.
_______________________________________________________ If we all had the same (g |
cheers, i'll probably go for that now. how much power can it handle? (for further down the track. big plans :) ) are there any chev trucks that use the muncie? so i could pinch the clutch. i'm assuming it fits in the trans tunnel without any massagi Edited by user Sunday, 24 February 2008 9:38:59 AM(UTC)
| Reason: Not specified
cheers, ill probably go for that now. how much power can it handle? (for further down the track. big plans :) ) are there any chev trucks that use the muncie? so i could pinch the clutch. im assuming it fits in the trans tunnel without any massaging Edited by user Sunday, 24 February 2008 9:38:59 AM(UTC)
HQd had Muncies, and had a small hump added to clear the shifter which I think was a Hurst. I have a Muncie here that was in a VK behind a 308 and it didnt have any tunnel mods and used the stock 4spd hole. When and if you go to do the conversion ill sell |
HQ'd had Muncies, and had a small hump added to clear the shifter which I think was a Hurst. I have a Muncie here that was in a VK behind a 308 and it didn't have any tunnel mods and used the stock 4spd hole. When and if you go to do the conversion i'll s |
sounds good. do they have an aftermarket though? as after this mild turbo motor, a turbo stroker will be on the way. read: 900hp.
cheers mate. very helpful.
If nissan motorsport is nismo, then doesnt that make honda motorsport H
I wouldn't be running a manual behind such an engine. Use a TH400.
I wouldnt be running a manual behind such an engine. Use a TH400.
why not a manual? if i did go auto, i would use that but i like manuals better.
