boom Offline
#1 Posted : Saturday, 23 February 2008 11:38:19 AM(UTC)
boom
Hi guys,
i know its a ford box, but it's strong, and it's cheap. so tell me guys, will it fit in a VK commodore trans tunnel? clutch and bellhousing are not a problem.
Alex
#2 Posted : Saturday, 23 February 2008 10:00:10 PM(UTC)
Hi Boom, I think that the gearbox fits in the tunnel fine but I am not so sure on the shifter/linkages.
Have you considered fitting a single rail gearbox from a Cortina as these can be bought very cheaply. Same bellhousing and clutch, speedo cable etc.
boom Offline
#3 Posted : Saturday, 23 February 2008 11:13:40 PM(UTC)
boom
needs to handle huge amounts of power/thrashing so, i don't think i'll be going single rail. but thanks for the tip.
i'm going custom console, so i don't mind cutting another hole for the new linkages.
BTW does anybody actually know how much power a
boom Offline
#4 Posted : Saturday, 23 February 2008 11:13:40 PM(UTC)
boom
needs to handle huge amounts of power/thrashing so, i dont think ill be going single rail. but thanks for the tip.
im going custom console, so i dont mind cutting another hole for the new linkages.
BTW does anybody actually know how much power a top
#5 Posted : Saturday, 23 February 2008 11:51:25 PM(UTC)
Was thanked: 612 time(s) in 579 post(s)
My mates HK used to bust them regularly with about 400hp (350 Chev). He ended up going back to a Muncie and has never blown one of those.
If we all had the same (good) taste, who would buy all th
#6 Posted : Saturday, 23 February 2008 11:51:25 PM(UTC)
My mate's HK used to bust them regularly with about 400hp (350 Chev). He ended up going back to a Muncie and has never blown one of those.
boom Offline
#7 Posted : Sunday, 24 February 2008 4:22:33 AM(UTC)
boom
yeah? how much are muncies going for atm? will it fit in the tunnel?
a muncie would be easier, as i can use the saginaw bellhousing as you previously mentioned.
boom Offline
#8 Posted : Sunday, 24 February 2008 4:22:33 AM(UTC)
boom
If nissan motorsport is nismo, then doesnt that make honda motors
#9 Posted : Sunday, 24 February 2008 7:24:27 AM(UTC)
Probably close to a good toploader in cost. You should find one for $750, except for the original HQ style which are worth good money because they belong to HQ GTS 350's.
#10 Posted : Sunday, 24 February 2008 7:24:27 AM(UTC)
Probably close to a good toploader in cost. You should find one for $750, except for the original HQ style which are worth good money because they belong to HQ GTS 350s.
boom Offline
#11 Posted : Sunday, 24 February 2008 9:37:50 AM(UTC)
boom
cheers, i'll probably go for that now. how much power can it handle? (for further down the track. big plans :) )
are there any chev trucks that use the muncie? so i could pinch the clutch.
i'm assuming it fits in the trans tunnel without any massagi
Edited by user Sunday, 24 February 2008 9:38:59 AM(UTC)  | Reason: Not specified
boom Offline
#12 Posted : Sunday, 24 February 2008 9:37:50 AM(UTC)
boom
cheers, ill probably go for that now. how much power can it handle? (for further down the track. big plans :) )
im assuming it fits in the trans tunnel without any massaging
#13 Posted : Sunday, 24 February 2008 8:57:34 PM(UTC)
HQd had Muncies, and had a small hump added to clear the shifter which I think was a Hurst. I have a Muncie here that was in a VK behind a 308 and it didnt have any tunnel mods and used the stock 4spd hole. When and if you go to do the conversion ill sell
#14 Posted : Sunday, 24 February 2008 8:57:34 PM(UTC)
HQ'd had Muncies, and had a small hump added to clear the shifter which I think was a Hurst. I have a Muncie here that was in a VK behind a 308 and it didn't have any tunnel mods and used the stock 4spd hole. When and if you go to do the conversion i'll s
boom Offline
#15 Posted : Sunday, 24 February 2008 9:10:23 PM(UTC)
boom
sounds good. do they have an aftermarket though? as after this mild turbo motor, a turbo stroker will be on the way. read: 900hp.
cheers mate. very helpful.
If nissan motorsport is nismo, then doesnt that make honda motorsport H
boom Offline
#16 Posted : Sunday, 24 February 2008 9:10:23 PM(UTC)
boom
#17 Posted : Monday, 25 February 2008 1:28:35 AM(UTC)
I wouldn't be running a manual behind such an engine. Use a TH400.
#18 Posted : Monday, 25 February 2008 1:28:35 AM(UTC)
I wouldnt be running a manual behind such an engine. Use a TH400.
boom Offline
#19 Posted : Monday, 25 February 2008 5:03:15 AM(UTC)
boom
why not a manual? if i did go auto, i would use that but i like manuals better.
boom Offline
#20 Posted : Monday, 25 February 2008 5:03:15 AM(UTC)
boom
