308hjute Offline
#1 Posted : Saturday, 19 April 2008 6:29:38 PM(UTC)
308hjute
Guys,
Anyone running a V8 in a HZ with 3 core radiator, shroud and clutch fan - do you have a spacer between the fan and the waterpump pulley?
My fan is extremely close to the crank pulley (3 groove).
Kev
#2 Posted : Saturday, 19 April 2008 7:28:54 PM(UTC)
Was thanked: 613 time(s) in 580 post(s)
Is it a factory HQ-HZ clutch fam and shroud?
308hjute Offline
#3 Posted : Saturday, 19 April 2008 7:38:58 PM(UTC)
308hjute
Hi Byron,
Yep, standard 3 core radiator and shroud, although I think the fan is actually from a later model.
Reason I asked (apart from the fan being extremely close to the lower pulley) is that I know there is a small spacer available, but not sure
#4 Posted : Saturday, 19 April 2008 9:09:32 PM(UTC)
A later model fan with square blades won't work with the HQ-HZ shroud. The HQ-HZ fan has rounded blades. I'll see what I can find.
If we all had the same (good) taste, who would buy all the Fords
#5 Posted : Saturday, 19 April 2008 9:09:32 PM(UTC)
A later model fan with square blades wont work with the HQ-HZ shroud. The HQ-HZ fan has rounded blades. Ill see what I can find.
308hjute Offline
#6 Posted : Saturday, 19 April 2008 10:41:17 PM(UTC)
308hjute
Byron,
Couple of pics of the fan and where it sits if that helps.
[IMG]http://i47.photobucket.com
#7 Posted : Saturday, 19 April 2008 11:34:37 PM(UTC)
it looks like am after macket air pully
crowe Offline
#8 Posted : Sunday, 20 April 2008 5:58:02 AM(UTC)
crowe
Looking at your pictures I think I can see the Acc AirCon pully (the one near your blades) and a factory water/alternater and power steer pully. The AirCon one is its own insert and you should be able to remove it by undoing the 4 bolts that hold it to th
308hjute Offline
#9 Posted : Sunday, 20 April 2008 8:37:56 AM(UTC)
308hjute
Crowe,
Cheers for that.
Yep, thought I could take the air con pulley off.
However, had a bit more of a look at it today and think Byron might be on the right track... If I put the spacer on with the current fan, it will hit the inside of the
crowe Offline
#10 Posted : Sunday, 20 April 2008 9:26:13 AM(UTC)
crowe
I have a curved edge fan and looking at your pic yes i see what you mean. you need to space your fan to max vacuum capacity ie- the outer part of your blade has min clearance to shrould. always remember as fan rpm increases the blades will naturaly flex i
#11 Posted : Sunday, 20 April 2008 6:54:48 PM(UTC)
That's a WB onwards fan. See if you can get a HZ taxi (6cyl with the same radiator) shroud. HQ 350 Chev shroud is nearlly the same - Rare's might have these. Then you can push the fan further forward. Show me a better photo of the shroud.
_____________
#12 Posted : Sunday, 20 April 2008 6:54:48 PM(UTC)
Thats a WB onwards fan. See if you can get a HZ taxi (6cyl with the same radiator) shroud. HQ 350 Chev shroud is nearlly the same - Rares might have these. Then you can push the fan further forward. Show me a better photo of the shroud.
_______________
308hjute Offline
#13 Posted : Sunday, 20 April 2008 7:03:09 PM(UTC)
308hjute
Byron,
The shroud is standard HZ V8. Re: the fan, I think it came off a VH I wrecked out a couple of years ago. Shouldnt I be able to get the correct fan for HZ with this shroud? Will get another pic of the shroud this morning.
Kev
308hjute Offline
#14 Posted : Sunday, 20 April 2008 7:03:09 PM(UTC)
308hjute
Byron,
The shroud is standard HZ V8. Re: the fan, I think it came off a VH I wrecked out a couple of years ago. Shouldn't I be able to get the correct fan for HZ with this shroud? Will get another pic of the shroud this morning.
Kev
308hjute Offline
#15 Posted : Sunday, 20 April 2008 7:38:34 PM(UTC)
308hjute
Shroud is the same as this one;
#16 Posted : Monday, 21 April 2008 5:36:20 PM(UTC)
You will be able to get the original one, although I reckon the one you have is a better fan. I tried to make that fan work with that shroud and a 3/4/5 row radiator in my HZ Overlander and it wouldn't fit, but I was using the longer waterpump (bigger bea
#17 Posted : Monday, 21 April 2008 5:36:20 PM(UTC)
You will be able to get the original one, although I reckon the one you have is a better fan. I tried to make that fan work with that shroud and a 3/4/5 row radiator in my HZ Overlander and it wouldnt fit, but I was using the longer waterpump (bigger bear
308hjute Offline
#18 Posted : Monday, 21 April 2008 6:31:56 PM(UTC)
308hjute
Byron,
Thanks for you help. I will try to get the correct fan and give that a go first. Failing that, do you know the part # for the 6 cylinder shroud or is there only one style?
Kev
Guest (6)
