Joined: 2/03/2005(UTC) Posts: 117  ![Australia Australia]()
Guys,
Anyone running a V8 in a HZ with 3 core radiator, shroud and clutch fan - do you have a spacer between the fan and the waterpump pulley?
My fan is extremely close to the crank pulley (3 groove).
Kev
Is it a factory HQ-HZ clutch fam and shroud?
Hi Byron,
Yep, standard 3 core radiator and shroud, although I think the fan is actually from a later model.
Reason I asked (apart from the fan being extremely close to the lower pulley) is that I know there is a small spacer available, but not sure
A later model fan with square blades won't work with the HQ-HZ shroud. The HQ-HZ fan has rounded blades. I'll see what I can find.
_______________________________________________________ If we all had the same (good) taste, who would buy all the Fords |
A later model fan with square blades wont work with the HQ-HZ shroud. The HQ-HZ fan has rounded blades. Ill see what I can find.
Byron, Couple of pics of the fan and where it sits if that helps.   [IMG]http://i47.photobucket.com
it looks like am after macket air pully
Joined: 3/03/2005(UTC) Posts: 287 ![Australia Australia]()
Looking at your pictures I think I can see the Acc AirCon pully (the one near your blades) and a factory water/alternater and power steer pully. The AirCon one is its own insert and you should be able to remove it by undoing the 4 bolts that hold it to th
Crowe,
Cheers for that.
Yep, thought I could take the air con pulley off.
However, had a bit more of a look at it today and think Byron might be on the right track... If I put the spacer on with the current fan, it will hit the inside of the
I have a curved edge fan and looking at your pic yes i see what you mean. you need to space your fan to max vacuum capacity ie- the outer part of your blade has min clearance to shrould. always remember as fan rpm increases the blades will naturaly flex i
That's a WB onwards fan. See if you can get a HZ taxi (6cyl with the same radiator) shroud. HQ 350 Chev shroud is nearlly the same - Rare's might have these. Then you can push the fan further forward. Show me a better photo of the shroud.
_____________ |
Thats a WB onwards fan. See if you can get a HZ taxi (6cyl with the same radiator) shroud. HQ 350 Chev shroud is nearlly the same - Rares might have these. Then you can push the fan further forward. Show me a better photo of the shroud.
_______________ |
Byron, The shroud is standard HZ V8. Re: the fan, I think it came off a VH I wrecked out a couple of years ago. Shouldnt I be able to get the correct fan for HZ with this shroud? Will get another pic of the shroud this morning.
Kev
Byron, The shroud is standard HZ V8. Re: the fan, I think it came off a VH I wrecked out a couple of years ago. Shouldn't I be able to get the correct fan for HZ with this shroud? Will get another pic of the shroud this morning.
Kev
Shroud is the same as this one;
You will be able to get the original one, although I reckon the one you have is a better fan. I tried to make that fan work with that shroud and a 3/4/5 row radiator in my HZ Overlander and it wouldn't fit, but I was using the longer waterpump (bigger bea |
You will be able to get the original one, although I reckon the one you have is a better fan. I tried to make that fan work with that shroud and a 3/4/5 row radiator in my HZ Overlander and it wouldnt fit, but I was using the longer waterpump (bigger bear |
Byron,
Thanks for you help. I will try to get the correct fan and give that a go first. Failing that, do you know the part # for the 6 cylinder shroud or is there only one style?
Kev
