28 Pages«<1415161718>»
the eh Offline
#301 Posted : Saturday, 7 May 2016 9:45:43 PM(UTC)
the eh
Sandblasted the old extractors off my car. these will be used on the ute project.
the eh Offline
#302 Posted : Sunday, 15 May 2016 6:12:58 PM(UTC)
the eh
Ute ready to go for a trip to get the rusty inner and outer sills removed
the eh Offline
#303 Posted : Saturday, 21 May 2016 9:59:31 PM(UTC)
the eh
Handbrake cable brackets added to the diff housing.
Sway bar mounts added.
All the welding complete. Ready for paint and brake reassembly.
Edited by user Saturday, 21 May 2016 10:02:34 PM(UTC)  | Reason: Not specified
the eh Offline
#304 Posted : Saturday, 21 May 2016 10:04:02 PM(UTC)
the eh
Some of the A/C hoses crimped.
the eh Offline
#305 Posted : Saturday, 11 June 2016 8:16:51 PM(UTC)
the eh
Underdash assemblies finalised. EPAS column from a XC Barina. Modified EH pedal box with 7" dual diaphragm booster that is modified to take a VT-VY brake master cylinder. Commodore accelerator pedal modified to have the cable exit the firewall in the same place as the original linkage.
Seat belt mounting plates made 5000sq mm which is larger than the 3750sq mm required under VSCCS
Replacement inner and outer sills ready to be fitted..
the eh Offline
#306 Posted : Sunday, 12 June 2016 7:06:29 PM(UTC)
the eh
Moved inside for some TLC
Started filling unwanted holes in the firewall and stripping the paint.
All done.
the eh Offline
#307 Posted : Monday, 13 June 2016 7:00:41 PM(UTC)
the eh
Firewall all welded, ground, sanded and deoxidised
Smaller holes were just filled with weld. No metal added. I just backed the hole with a copper plate whilst welding
All ready for shipping off to have the major rust repairs done..
the eh Offline
#308 Posted : Tuesday, 14 June 2016 7:30:56 PM(UTC)
the eh
Fitted a Commodore brake light switch to the modified EH pedal box.
the eh Offline
#309 Posted : Monday, 20 June 2016 7:15:04 PM(UTC)
the eh
The EH ute shell being wheeled into surgery. A week or so of metal cancer surgery and it should be good for another 50 years.
https://www.facebook.com...ocal_search?surface=tyah
the eh Offline
#310 Posted : Saturday, 25 June 2016 7:33:57 PM(UTC)
the eh
Alternate induction setup for the ute 308. I don't think I'll use it as I want this build done quickly.
the eh Offline
#311 Posted : Saturday, 25 June 2016 7:37:28 PM(UTC)
the eh
Engine for the ute build getting a cleanup for repainting.
the eh Offline
#312 Posted : Friday, 1 July 2016 7:19:37 PM(UTC)
the eh
New sills, inner and outer as well as new dog leg sections and some hand made sections to finish off the rear of the sill and rear wheel arch..
Unused holes welded.
Sills done
Prime and filled, ready for reassembly
Engine and transmission painted and ready to go back in. Colour is a secret at the moment.
the eh Offline
#313 Posted : Saturday, 9 July 2016 8:26:40 PM(UTC)
the eh
Rust repairs done and trailered back home. Back onto the rotisserie now to finish of the underside
A/c Condensor, transmission cooler and thermo fan module finished.
the eh Offline
#314 Posted : Sunday, 10 July 2016 6:56:27 PM(UTC)
the eh
New tailgate skin fitted.
Hidden box for A/C controls and extra switches.
Drivers side A Pillar was pushed in and needed repairing.
the eh Offline
#315 Posted : Saturday, 16 July 2016 8:25:58 PM(UTC)
the eh
BA Falcon calipers ready for rebuilding. These are going into the EH ute
Disassembled,sandblasted and casting flash linished off. Cleaned up with BrakeKleen and dried with compressed air.
Reassembled with new rubbers and Bendix pads..
Banksia handbrake kit fitted.
Stock BA V8 rear rotors painted and ready to fit.
All done
the eh Offline
#316 Posted : Saturday, 23 July 2016 8:09:56 PM(UTC)
the eh
4PK pulley for the A/C compressor and old school gilmer drive for alternator and water pump.
Fuel pressure reg mounted
All our hose fittings are going to be black or brushed alloy so this lot needs to be stripped of Anodizing. Sodium Chloride is the answer.
gm5735 Offline
#317 Posted : Saturday, 23 July 2016 10:27:57 PM(UTC)
gm5735
Looking good. They got cracking with that body work.
Maybe Sodium Hydroxide, and not Sodium Chloride?
the eh Offline
#318 Posted : Sunday, 24 July 2016 8:37:59 AM(UTC)
the eh
Haha, you are of course correct. Sodium chloride may not work. Might make it taste nicer though.
Happy with the bodywork. Very good work and as you said speedy service. The price was on par with other quotes also..
gm5735 Offline
#319 Posted : Sunday, 24 July 2016 12:56:39 PM(UTC)
gm5735
I suppose you could pop some in the sandblaster, and use it as a mild abrasive.
Or mix it with water and stick a few amps through it. Then you'd get your Sodium Hydroxide, and some chlorine gas for good measure.
the eh Offline
#320 Posted : Friday, 5 August 2016 7:32:39 PM(UTC)
the eh
A few weekends work on the subframes. Braces the steering shaft centre bearing mount. Braced the outer sides of the subframe where the radiator cutout has been made. Filled all the unwanted holes..
Guest (5)
This page was generated in 0.123 seconds.
