#1 Posted : Tuesday, 15 June 2021 12:53:17 PM(UTC)
Just out of curiosity, is there a better after market shifter to suit a M20/21 Aussie 4 speed?
#2 Posted : Tuesday, 15 June 2021 2:27:08 PM(UTC)
A new one from Rare Spares maybe that isn’t all sloppy. Speco used to sell an aftermarket shifter but I think the need for them died when people started throwing Aussie 4spds in the bin. The last time I had one, also in a WB, I swapped it out for a VK Trimatic and TH400 shifter. At the time I just grabbed a B&M cooler off a wreck and got some plastic coated 5/16” LPG copper pipe and bent it up to suit. TH400 shifter came with the harness that plugs straight into the WB harness. It actually made it a far more pleasant far to drive, and I left the clutch pedal there as a foot rest!
I’d probably have an auto console insert here that will go straight into your console too.
#3 Posted : Tuesday, 15 June 2021 2:55:58 PM(UTC)
no... in my opinion
nothing wrong with the factory shifter, as long as they are properly adjusted (as the case with the clutch)
SPECO did an aftermarket version, now no longer available for a number of years but (having had one)
it is no better than the genuine article ! the cross shaft does bind up so people loosen the retaining nut
and the whole thing gets sloppy
#4 Posted : Tuesday, 15 June 2021 3:00:54 PM(UTC)
oh.. and having the right adjustment tool helps
Steve Tav Offline
#5 Posted : Saturday, 19 February 2022 10:16:46 PM(UTC)
Steve Tav
Would anyone have this alignment tool by any chance? I would like to rebuild my box and shifter but I can't find anything about this tool.
If someone has it and is willing to share the dimensions I can replicate the tool
Thank you
