HJPVAN Offline
#1 Posted : Saturday, 20 November 2021 7:11:48 PM(UTC)
HJPVAN
GDay All
I am having an common issue with a aussie 4 speed gearbox in my HJ Pano, it's jambing between reverse and all other gears and the only way to free it up is to tow it forward/backward with another car, I have had a gearbox kit and shifter kit put in but this problem is still happening. Can anyone suggest a solution to this problem???? I would really appreciate your input....
#2 Posted : Sunday, 21 November 2021 7:16:12 AM(UTC)
Aussie 4spds are known for this, but as far as I am aware the bit that stops it from happening is the shifter and it is normally a symptom of a worn out shifter. If the person who put a kit through it knew what they were doing the box should be OK as they would have replaced any worn bits like cluster, 1-2 gear, main shaft, input shaft, selectors and synchros. You can buy new shifters for them now.
8D11PCH2 Offline
#3 Posted : Sunday, 21 November 2021 7:54:37 AM(UTC)
8D11PCH2
Agree, a worn shifter will be the issue, not the gearbox.
HJPVAN Offline
#4 Posted : Sunday, 21 November 2021 9:26:38 AM(UTC)
HJPVAN
Thank you for the reply,
That all makes sense, now I have something to follow up on hopefully just a few adjustments not a few $$$.
Much appreciated!!! I will let you know how it works out.
HJPVAN Offline
#5 Posted : Thursday, 30 December 2021 12:25:16 PM(UTC)
HJPVAN
Okay,My HJ Pano AUSSIE 4 SPEED was sticking between gears and we were becoming very frustrated with this so we took the advise from the expert members who replied to my post, put in a brand NEW SHIFTER & LINKAGES kit then "BINGO" she is back on the road and cruising
like it should be.
A big thank you to HK1837 & 8D11PCLH2 your advise is priceless!!!
SAFE & HAPPY NEW YEAR TO ALL
8D11PCH2 Offline
#6 Posted : Friday, 7 January 2022 1:29:48 PM(UTC)
8D11PCH2
like it should be.
A big thank you to HK1837 & 8D11PCH2 your advise is priceless!!!
ThumpUp
Edited by user Friday, 7 January 2022 1:30:36 PM(UTC)  | Reason: Not specified
This page was generated in 0.083 seconds.
