Joined: 20/11/2021(UTC) Posts: 3 ![Australia Australia]() Location: Victoria
GDay All I am having an common issue with a aussie 4 speed gearbox in my HJ Pano, it's jambing between reverse and all other gears and the only way to free it up is to tow it forward/backward with another car, I have had a gearbox kit and shifter kit put in but this problem is still happening. Can anyone suggest a solution to this problem???? I would really appreciate your input....
Thanks: 1 times Was thanked: 610 time(s) in 577 post(s)
Aussie 4spds are known for this, but as far as I am aware the bit that stops it from happening is the shifter and it is normally a symptom of a worn out shifter. If the person who put a kit through it knew what they were doing the box should be OK as they would have replaced any worn bits like cluster, 1-2 gear, main shaft, input shaft, selectors and synchros. You can buy new shifters for them now. |
Joined: 11/09/2016(UTC) Posts: 231 ![Australia Australia]() Location: OZ Was thanked: 28 time(s) in 26 post(s)
Originally Posted by: HK1837  Aussie 4spds are known for this, but as far as I am aware the bit that stops it from happening is the shifter and it is normally a symptom of a worn out shifter. If the person who put a kit through it knew what they were doing the box should be OK as they would have replaced any worn bits like cluster, 1-2 gear, main shaft, input shaft, selectors and synchros. You can buy new shifters for them now. Agree, a worn shifter will be the issue, not the gearbox.
Thank you for the reply, That all makes sense, now I have something to follow up on hopefully just a few adjustments not a few $$$. Much appreciated!!! I will let you know how it works out.
Okay,My HJ Pano AUSSIE 4 SPEED was sticking between gears and we were becoming very frustrated with this so we took the advise from the expert members who replied to my post, put in a brand NEW SHIFTER & LINKAGES kit then "BINGO" she is back on the road and cruising like it should be. A big thank you to HK1837 & 8D11PCLH2 your advise is priceless!!! SAFE & HAPPY NEW YEAR TO ALL
Originally Posted by: HJPVAN  Okay,My HJ Pano AUSSIE 4 SPEED was sticking between gears and we were becoming very frustrated with this so we took the advise from the expert members who replied to my post, put in a brand NEW SHIFTER & LINKAGES kit then "BINGO" she is back on the road and cruising like it should be. A big thank you to HK1837 & 8D11PCH2 your advise is priceless!!! SAFE & HAPPY NEW YEAR TO ALL  Edited by user Friday, 7 January 2022 1:30:36 PM(UTC)
| Reason: Not specified
