Dave327 Offline
#1 Posted : Wednesday, 18 May 2022 4:35:42 PM(UTC)
Dave327
Hi guys first time member and post,
I have a leaky rear axel, I'd like to know if I have to remove the backing plate salisbury 10 bolt, to take the axel out as I wanted to take it some where to
Have a new bearing and seal put on
#2 Posted : Wednesday, 18 May 2022 5:03:38 PM(UTC)
Is it on a Holden or a Camaro? On a Holden they use a normal Holden style attachment to the axle tube just like a banjo, but a Camaro will have a C-clip that needs the rear plate removed to free up the axle.
Dave327 Offline
#3 Posted : Wednesday, 18 May 2022 6:44:04 PM(UTC)
Dave327
It's on a Holden' I just wasn't sure if I had to take the cover plate off and undo something in there. Do I have to take it off to pull the axel out
#4 Posted : Wednesday, 18 May 2022 6:45:59 PM(UTC)
Same as a banjo or a HQ-VK Salisbury.
Dave327 Offline
#5 Posted : Wednesday, 18 May 2022 6:51:21 PM(UTC)
Dave327
I've never pulled an axel out before, I know my way around a transmission and motor but the diff is all new to me. Some information would be greatly appreciated
HK-Q-Z5.0Lfan Offline
#6 Posted : Wednesday, 18 May 2022 7:30:41 PM(UTC)
HK-Q-Z5.0Lfan
Jack & chassis stand
Wheel off
Drum off
4 x 9/16 nuts & spring washers off the retainer plate
Hammer, slide hammer what ever you need
I have an old axle cut to about 300mm with the studs knocked out. Put it on one wheel stud, with wheel nut on loose, grab cut shaft of axle (with left hand) & belt the flange below where it's bolted to your axle, usually 2 hits does it
KBM Offline
#7 Posted : Thursday, 19 May 2022 9:28:16 AM(UTC)
KBM
I find it easy to put drum on backwards and nuts on loose with flat end towards drum. Works great as a slide hammer.
 1 user thanked KBM for this useful post.
202tonner on 19/05/2022(UTC)
Balfizar Offline
#8 Posted : Thursday, 19 May 2022 11:14:50 AM(UTC)
Balfizar
Was thanked: 16 time(s) in 16 post(s)
I find that the full range of GMH workshop manuals works fine every time.
And specifically VK Wagon with EFI & Axle M39313 June, 1985 Fading Gray to White
there may be earlier Axle manuals.
Edited by user Thursday, 19 May 2022 11:15:33 AM(UTC)  | Reason: Not specified
Guest (7)
This page was generated in 0.105 seconds.
