Taztiger4 Offline
#1 Posted : Sunday, 19 February 2023 10:46:42 AM(UTC)
Taztiger4
Hi
Trying to fit centre lap only belt in my HJ 1 tonner with bench seat.
Did they originally come with centre lap belt ?
If so, Where do they bolt to on floor ?, with the stalks for driver & passenger under 1 bolt or did they have their own mounting nut in floor ?
Thanks in advance
#2 Posted : Sunday, 19 February 2023 11:56:24 AM(UTC)
Yes, all bench seat cars were 3 seat belts. The captive/welded nuts are shared with the outer seats. You need the right bolts, spacers etc. When I get time I'll scan you a picture.
Taztiger4 on 19/02/2023(UTC)
Taztiger4 Offline
#3 Posted : Sunday, 19 February 2023 9:21:01 PM(UTC)
Taztiger4
very much appreciated if you could do that
thankyou
#4 Posted : Monday, 20 February 2023 6:26:05 AM(UTC)
Remember also, if pre 1/1/75 it will be 2 x lap/sah and 1 x centre lap belt. If 1/1/75 onwards it will be 2 x retractable and one lap belt.
Taztiger4 on 20/02/2023(UTC)
Taztiger4 Offline
#5 Posted : Monday, 20 February 2023 8:21:18 AM(UTC)
Taztiger4
Thankyou again kind Sir, a photo or even a sketch of that arrangement would be muchly appreciated
#6 Posted : Monday, 20 February 2023 12:45:18 PM(UTC)
This will help. Section B-B down the bottom (top images are sedan/wagon)
Part/drawing number 120384 is a split washer.
Item 7 is the spacer that allows the soft belt anchor to rotate. It is the same part for sedan/wagon/statesman as well with bench seat and continues into HX and HZ.
The bit under the bolt head is item 2 (the belt buckle for the outer seating positions), it sort of shows better on the sedan section B-B. This buckle is unique to commercial but I think it is the same as the commercial with bucket seats.
Taztiger4 Offline
#7 Posted : Monday, 20 February 2023 8:53:17 PM(UTC)
Taztiger4
Thanks again, I reckon I can make that work
