holden05 Offline
#1 Posted : Saturday, 18 November 2023 12:25:36 PM(UTC)
holden05
Got wb out of storage and noticed the tacho(gts type) flickered and died also no power to the radio
Any ideas?
Thinking maybe bad earth?
#2 Posted : Saturday, 18 November 2023 4:13:53 PM(UTC)
Could just be a fuse, could be a bad chassis connection. Might be a dead voltage regulator or crook capacitors too. But start on the easy stuff first like fuses and chassis 0V connection.
holden05 Offline
#3 Posted : Saturday, 18 November 2023 4:24:27 PM(UTC)
holden05
Got the radio working, tacho still dead. Traced wiring back from coil to harness, looks ok
Check coil connector, cleaned and lubed
Still nothing
all other gauges work ok
Edited by user Saturday, 18 November 2023 5:01:31 PM(UTC)  | Reason: Not specified
#4 Posted : Sunday, 19 November 2023 7:59:33 AM(UTC)
My tachometer played up years ago, used to jump all over the place. Sent it to an instrument place and they resoldered all the joints I believe. Never played up again. The clock hasn’t missed a beat in 39 years, so I guess you never can tell.
holden05 Offline
#5 Posted : Sunday, 19 November 2023 10:11:53 AM(UTC)
holden05
If it was a bad earth wouldn’t I be having problems with the other guages?
202tonner Offline
#6 Posted : Sunday, 19 November 2023 11:59:20 AM(UTC)
202tonner
What was wrong with the radio? That might point to the problem.
Offhand I would check the connection at the firewall connector. Should be a brown wire both sides. Give it a wiggle and/or a thump. If you are technically minded check the connectivity of the wire from the tacho to the coil using a multimeter.
I'm not familiar with GTS dashes or wiring but do you get a light in the tacho when you turn the headlights on? What colour wires come off the back of the tacho?
Also "flickered and died"? So it worked for a second or a minute? Or just jumped up a bit and then nothing since?
Edited by user Sunday, 19 November 2023 12:00:08 PM(UTC)  | Reason: Not specified
holden05 Offline
#7 Posted : Sunday, 19 November 2023 12:38:48 PM(UTC)
holden05
The radio was user error, lol.
The tacho flickered and then died. Previous to the vehicle being stored
It worked flawlessly
I’ve checked both firewall connection and on the coil
Both looked ok
I had a visual inspection of the cable from coil to the tacho
Looks ok
Yet to do a continuity test as the cable didn’t look damaged
Edited by user Sunday, 19 November 2023 12:55:16 PM(UTC)  | Reason: Not specified
morsesworld Offline
#8 Posted : Monday, 20 November 2023 2:00:17 PM(UTC)
morsesworld
I would say probably bad solder Joints.
My VN Commodore has the same problem.
holden05 Offline
#9 Posted : Monday, 20 November 2023 5:45:11 PM(UTC)
holden05
Update to this
Did notice today there is a very slight flicker
In the needle
So it must be getting signal from the coil?
202tonner Offline
#10 Posted : Monday, 20 November 2023 6:44:30 PM(UTC)
202tonner
Check the connectivity as mentioned above. The firewall connector can fill up with crud and any holes or leaks in the plenum will trickle water down into it. It might look fine but the connection might be dirty or corroded. Worth checking.
If that wire is fine then connect the tacho with new wires outside of the loom. So run a power wire from the fusebox, a new wire to the coil, a new earth to somewhere and whatever other wires are there. If the tacho works then it is a wiring problem somewhere and you can replace these new wires one by one with the old wires in the loom until it stops working again. That will be the dodgy wire.
If the tacho still doesn't work properly with all new wires then get it checked out by an auto sparky or electronics dude. Something is wrong inside.
Good luck.
#11 Posted : Monday, 20 November 2023 7:28:53 PM(UTC)
As I said, my GTS tachometer did the same, it was dry solder joints. Pull it out and take it to an instrument repair place. If it was your clock it would be capacitors that had stopped working.
Edited by user Monday, 20 November 2023 7:29:57 PM(UTC)  | Reason: Not specified
holden05 Offline
#12 Posted : Monday, 20 November 2023 8:16:04 PM(UTC)
holden05
I’ll replace the tacho to coil cable just in case
Trace out the power wire which I understand connects to the ignition side on the fuse box(pink wire??)
If it is a bad earth then the earth must be a single cable to chassis and if it was grouped I’d be having issues with other guages????
Lastley I’ll remove the tacho and get it tested, can you remove the tacho by its self or do I have to remove all the other guages?
Edited by user Monday, 20 November 2023 8:22:29 PM(UTC)  | Reason: Not specified
#13 Posted : Monday, 20 November 2023 8:20:07 PM(UTC)
Yes. Pull the tacos off and then remove the tachometer
holden05 Offline
#14 Posted : Monday, 20 November 2023 8:46:20 PM(UTC)
holden05
I have read elsewhere that you can test a tacho with a battery charger as it emits a pulse
Anyone else heard this
202tonner Offline
#15 Posted : Monday, 20 November 2023 11:10:26 PM(UTC)
202tonner
I hadn't but apparently you can.
Here's the info on MG tachos. Note some the old pommie stuff used positive earth so not sure how to wire it for a negative earth Holden.
http://www.mgb-stuff.org.uk/tachtest.htm
Search "how to test a tacho with a battery charger" for more examples.
holden05 Offline
#16 Posted : Tuesday, 21 November 2023 8:35:19 PM(UTC)
holden05
Another strange thing, not sure if connection but dash lights are dim
holden05 Offline
#17 Posted : Thursday, 7 December 2023 6:25:39 PM(UTC)
holden05
Tacho all good now working
#18 Posted : Friday, 8 December 2023 5:26:00 AM(UTC)
What was wrong with it?
holden05 Offline
#19 Posted : Friday, 8 December 2023 1:21:05 PM(UTC)
holden05
dunno!. took the car for a run before i was going to remove the tacho, gave it a big rev on the way and it cam good and stayed that way. so fingers cross all good for now
This page was generated in 0.104 seconds.
