holden05 Offline
#1 Posted : Wednesday, 27 December 2023 3:56:41 PM(UTC)
holden05
What is the process here. Car is a v8 auto
#2 Posted : Thursday, 28 December 2023 12:09:37 PM(UTC)
Vc commodore radiator removal? V8 auto?
remove temp sensor harness (if fitted.. some have a temp sensor for A/C in a side tank)
remove auto trans lines from side tank
remove top and bottom radiator hoses (note - bottom can be removed at pump outlet if you cannot get the clamp off the hose at the radiator).. beware coolant will go everywhere when the bottom hose is removed
remove top radiator shroud (on top rad panel) .. lever out retainers
remove overflow tube (from where it connects at the side of the top where the cap is (note cap does NOT need removing)
remove 2 side clips (sitting in front panel retainers) by pressing down and levering out
pull radiator straight up (note the side rubber vibration blocks might be a bit stuck.. just jiggle sideways if so)
done ...
holden05 Offline
#3 Posted : Thursday, 28 December 2023 2:23:13 PM(UTC)
holden05
To get to the auto trans lines, do I remove the grill or can I get to them once I’ve removed the top panel?
#4 Posted : Thursday, 28 December 2023 5:42:31 PM(UTC)
neither
from the passenger side... look behind the headligh at the radiator, you can see the auto trans fluid pipes coming from under the car and up to the radiator
they are shown here .. on the passenger side tank above the bottom hose connector
#5 Posted : Thursday, 28 December 2023 5:44:47 PM(UTC)
here is an aftermarket rad for VB-VK V8s and you can see more clearly the 2 pipe connectors
this one also has a temp sensor boss under the top rad hose connector on the drivers side
Edited by user Thursday, 28 December 2023 5:46:04 PM(UTC)  | Reason: Not specified
holden05 Offline
#6 Posted : Thursday, 28 December 2023 9:21:54 PM(UTC)
holden05
Ok, I’ll have to check that out. I’m not near the car at the moment but would I be right in saying that they would be more accessible once the fan shroud is removed?
#7 Posted : Friday, 29 December 2023 7:10:27 AM(UTC)
yes...
and the shroud may/may not have to come off to get the rad out
(no biggie as the factory shrouds need 2 screws undone at the top)
holden05 Offline
#8 Posted : Thursday, 4 January 2024 2:59:38 PM(UTC)
holden05
Is there a trick to getting the clips on the sides out?
#9 Posted : Thursday, 4 January 2024 7:14:54 PM(UTC)
no .. not really, it is just an upside down sort of W clip
but
how I do it, is to depress one side (either side... ) with a screwdriver and then put another screwdriver thru the middle (the sticking up bit) of the clip and twist
that will pull one end of the clip out of the retainer housing (that the rubber mount is in)
and once one end is out, tilt the clip and pull the other end out
Clips look like this
Edited by user Thursday, 4 January 2024 7:16:13 PM(UTC)  | Reason: Not specified
Guest (11)
