holden05 Offline
#1 Posted : Monday, 22 April 2024 3:21:37 PM(UTC)
holden05
hi, im going to remove the radiator from my vc hdt, it has air cond. does the condensor have to be removed as well?
#2 Posted : Monday, 22 April 2024 3:48:56 PM(UTC)
No, the job is fairly straight forward. Unbolt & lay the shroud back.
Undo the transmission lines & radiator hoses. Remove the side mount clips & lift the radiaor out (vertically).
holden05 Offline
#3 Posted : Monday, 22 April 2024 10:13:07 PM(UTC)
holden05
Thanks, is there a knack to getting the side clips out?
#4 Posted : Tuesday, 23 April 2024 7:28:09 AM(UTC)
Just use broad-nosed pliers.
#5 Posted : Tuesday, 23 April 2024 7:30:40 AM(UTC)
Was thanked: 40 time(s) in 39 post(s)
yeah.... long screwdriver and push down hard on one of the recesses of the clip (which is on top of a rubber mounting block)
then while pushing down, lean screwdriver over (towards the side of the car) and release the tang on the clip out of the body panel
pics might assist
holden05 Offline
#6 Posted : Tuesday, 23 April 2024 10:05:07 PM(UTC)
holden05
Does the plastic panel in front in front of the radiator have to be removed?
 1 user thanked holden05 for this useful post.
Smitty2 on 24/04/2024(UTC)
holden05 Offline
#7 Posted : Friday, 3 May 2024 6:26:13 PM(UTC)
holden05
The leak seems to be coming from the drivers side tank, so only when the thermo opens
It’s in one of the indents on the side of the tank
The radiator is original copper, I didn’t think a copper one would corrode?
#8 Posted : Friday, 3 May 2024 9:10:19 PM(UTC)
the solder that holds the side tank to the core crumbles (thru age and repeated heating)
any decent radiator shop can quickly fix this...
ps... you do not need an alloy rad to replace it
holden05 Offline
#9 Posted : Friday, 7 June 2024 6:35:00 PM(UTC)
holden05
Is there a way to get the radiator support panel trim off without marking it up?
