Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
hi, im going to remove the radiator from my vc hdt, it has air cond. does the condensor have to be removed as well?
Originally Posted by: holden05  hi, im going to remove the radiator from my vc hdt, it has air cond. does the condensor have to be removed as well? No, the job is fairly straight forward. Unbolt & lay the shroud back. Undo the transmission lines & radiator hoses. Remove the side mount clips & lift the radiaor out (vertically). Dr Terry |
Thanks, is there a knack to getting the side clips out?
Originally Posted by: holden05  Thanks, is there a knack to getting the side clips out? Just use broad-nosed pliers. Dr Terry |
Joined: 6/07/2019(UTC) Posts: 462 ![Australia Australia]() Location: bayside Melbourne Thanks: 298 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: holden05  Thanks, is there a knack to getting the side clips out? yeah.... long screwdriver and push down hard on one of the recesses of the clip (which is on top of a rubber mounting block) then while pushing down, lean screwdriver over (towards the side of the car) and release the tang on the clip out of the body panel pics might assist  |
Does the plastic panel in front in front of the radiator have to be removed?
 1 user thanked holden05 for this useful post.
The leak seems to be coming from the drivers side tank, so only when the thermo opens It’s in one of the indents on the side of the tank The radiator is original copper, I didn’t think a copper one would corrode?
Originally Posted by: holden05  The leak seems to be coming from the drivers side tank, so only when the thermo opens It’s in one of the indents on the side of the tank The radiator is original copper, I didn’t think a copper one would corrode? the solder that holds the side tank to the core crumbles (thru age and repeated heating) any decent radiator shop can quickly fix this... ps... you do not need an alloy rad to replace it |
Is there a way to get the radiator support panel trim off without marking it up?
