13 Pages«<10111213>
#221 Posted : Sunday, 22 September 2024 5:33:44 PM(UTC)
Originally Posted by: stevo Go to Quoted Post
what sort of f*cken idiot wants to drive a HZ at 185 k's they were all over the road by 160k's.
I disagree. They float a bit over 180 but they aren’t that bad. My WRX STI was definitely better though.
 1 user thanked wbute for this useful post.
castellan on 22/09/2024(UTC)
castellan Offline
#222 Posted : Sunday, 22 September 2024 5:46:10 PM(UTC)
castellan
I had a HJ Kingswood ute as a daily driver in the mid 90's. It was originally a 4.2, Trimatic and 2.78 rear axle but had been upgraded to basically a HQ 350 and TH400 setup, it wasn't an engine out of a HQ but was dressed as if it was one, same heads etc. It would easily sit at 150-160 on outback roads but it's steering, handling and braking prowess were no better than any other HQ-HX fitted with better tyres and sway bars. Far cry from something more modern like a V2 or VE etc.
HQ-HX I put Bendix metal king brake pads on mine and bingo that was a transfomation ! astounding braking power at speed ! and do not fade !
Quality Shocks and good tyres for hooking in is number one and then you can play with the Camber with more neg so as to sort out the crap understeer.
I found the VN-S Commodors floated about over 180 as well, not badly but enough to be carful of such. Not like a HR Holden at 110mph that was a real floater for sure.
Nut when the VT SS came out they did not float at all, only problem with them was the stupid rubbish IRS had no toe link until VX ser2 SS then you had a real car for once ! right off the show room floor briliant ! just add Bendix Ultimate and you have magic brakes !
The IRS from the VP to the VX was evil over 8 10ths as it you do not catch it before it wants to toss you off the road, you have to be real carful of that !
I had to laugh the first time i drove a VP with IRS i said to a mate what a total bucket of sh1t it was ! and he was like No ! IRS is King for handling ! What a load of total BS i said what about the Datsun 200B Haha ! I had a 240k Haha !
stevo Offline
#223 Posted : Monday, 23 September 2024 8:00:49 AM(UTC)
stevo
Where were the roads good enough in Australia to drive a hZ holden at 180k's? I drove a hz for 8 years I lived in the Territory when there was open speed limit . Keep the bullshit coming I've lost my licenece for speeding plenty of times.
How long did you stay at 180k? 30 seconds ? Where can you drive a HZ at 180 what was the accuracy of the speedo past 150?
Why doi Holden men allways bullshit?
GM bleed us dry and run away.
#224 Posted : Monday, 23 September 2024 8:43:07 AM(UTC)
The Hay plains in the 70s was good for 180+ km/h for more than 30 seconds. Done that a few times. As long as your front suspension has plenty of castor, stability is fine at speed.
stevo Offline
#225 Posted : Monday, 23 September 2024 8:51:08 AM(UTC)
stevo
When a HZ speedo read 180km how fast were you really going? The few I played with were 30 k's out by the time they read 180, one read 180 but the reality was it was doing about 150. The car had the orginal ratio diff the speedo was pretty close until about 120 k's.
Edited by user Monday, 23 September 2024 9:01:02 AM(UTC)  | Reason: Not specified
#226 Posted : Monday, 23 September 2024 8:59:43 AM(UTC)
Actually I did it in an HD (turbo 5-speed etc. etc.). I had a recalibrated speedo which was within 2% on the dyno.
stevo Offline
#227 Posted : Monday, 23 September 2024 9:04:18 AM(UTC)
stevo
what was the accuracy at 180 k's ?
#228 Posted : Monday, 23 September 2024 10:42:09 AM(UTC)
I drove that Hay plain in both directions a few years back, 2019 I think when all the bushfires were around Canberra and southern NSW. In my Supercharged Hilux towing a box trailer (picking up the Rodtech front end and 9" for the GTS). I found if I didn't sit on certain speeds I was getting overtaken by trucks! That Hilux was far more road stable at higher speeds than any HQ to WB I ever had, but it also had a lot more power than most HQ to HZ.
One of the famous dashboard errors in motoring journalism is the HO down the Hume article by Mel Nichols, but tacho rather than speedo. That famous photo (touched up for the magazine to show 104mph but later published properly) shows the car pulling 141.5mph but with tacho reading incorrectly at 6700rpm - the article and later Mel himself said it was 6150rpm as it kept hitting the rev limiter and killing the engine's power.
#229 Posted : Monday, 23 September 2024 10:59:17 AM(UTC)
The guy that built the speedo with a new face (220 km/h), bench tested it & said it was was good within 3.5% at full scale.
The dyno only when to around 135 km/h. So 2% at that speed verifies that.
Edited by user Monday, 23 September 2024 12:02:22 PM(UTC)  | Reason: Not specified
#230 Posted : Monday, 23 September 2024 12:42:09 PM(UTC)
actually they weren't ! .... at the HZ intro day at LangLang, quite a number of us invited GMH employees took advantage
of the 'come drive with me' invite from the guy who lead the RTS intro- Peter Hanenberger
A HZ GTS with Hanenberger at the wheel will happily run along the top lane of the speed bowl pretty much flat chat
at an indicated 200-210 (speedo) .... hands off!
That's good for a road car... and I compare that with the next time I got a ride around the speed bowl, fast!
In a VH Commodore race car with #05 on the door piloted (right word to use) by one PBrock, it did not like
being held there . Tacho said a tad over 6800 in top gear, Harves afterwards said thats about 280 with the gearing
at the time on #05
Quite fast enough thank you. The exhaust noise is the other thing I remember, no ear plugs in under the helmet ...
6800 from a Holden V8 is a glorious symphony but I was deaf with the next hour or so...
castellan Offline
#231 Posted : Monday, 23 September 2024 1:19:38 PM(UTC)
castellan
Try all the way from Bundaberg to Brisbane and back hundreds of times dude just taking it easy and at night many a time, she had spotlights dude. that's not even getting into it.
She had 3.08 diff 235/60 x14 tyres and sat on 4500rpm at 180KM/H Back in the 1980's you are not sitting on 180 all the way but just float up to that crusing speed easy as, not pussing it at all.
Oh i always had a radar detector. still got busted tho at times.
I had a XG Longreach ute and a mate drove it on the double lanes all the way to Brisbane at 210KM/H and it was cutting out at 210 found out that it was speed limited, the Ford dealership did not even know they were. then when the ED Falcon came out they were speed limited to 180KM/H
a mate bought a 1994 Longreach and he was spewing that it was limited to 180 because every morning to get to work he drove at 210KM/H In his XC 5.8L. We had a run with my XG and his XC and he went out directly and bought a New XG, because he was so impressed !
I road on the double lanes out and to Brisbane at 240KM/H taking it easy dude not pushing it at all, just playing it safe ! if a car pulled out into the right lane you just back off touch the brakes, you have washed off the speed easy as and then just back to 4th 5th then 6th in no time. Look the 1/4 in 9 sec dude and a quiet bike stock as a rock.
No one can do what i did unless you get your eye in ? and know your car or bike real well. I would never drive something that i did not own like that, you have to work out your tyre pressures etc you have to know what you are doing. the average dude would be dead in no time because they do not have a clue, if you think you are pushing yourself then you are going too fast dude !
I rode Enduro bikes as well and dude that's a way to challange yourself hooking in full on !
But i am in my 60's now and retired, i have no need to hook in and i would not do such because i am not that fit etc to bother with such.
castellan Offline
#232 Posted : Monday, 23 September 2024 2:03:58 PM(UTC)
castellan
at the time on #05
Yes i know Hannenberger showed off such things with the HZ RTS, THIS IS WHAT THEY MUST DO, HE SAID ! Flick the s wheel at whatever speed and catch it easy as !
Them HZ 5.OL 4sp were good to drive as hard as you liked the 6 cyl were just too gutless to totaly control, because you can use the gas peddle on a V8 to steer it hanging the tail out ! and you need at least the 4.2L in a VB to do that. For they were the best handling car off the showroom floor, the VC-H-K-L-N-P-R-S on was a dog ! UNDERSTEERING Crap and moronic oversteer ! but bad drivers love that crap. and such bagged Hanenberger in fact for making a car truly handel !
The idiots even have a Fix for the HZ that wheelaligners do, so as to turn the HZ into a bucket of sh1t like the HQ was. They think they are so bright ? Morons !
I have been in the car with Brock as well at Norwell, i was invited to test drive all of the new VU Commodores and at the Opening day of the new VE Utes.
Brock was taught to not abuse a car, and the science regarding what he was truly doing and work it all out, that's why he was the King of the Mountain. he did not just turn up and race for the hell of it !
Blu253 Offline
#233 Posted : Saturday, 28 June 2025 12:37:26 AM(UTC)
Blu253
Originally Posted by: Dr Terry Go to Quoted Post
Originally Posted by: Torana1978 Go to Quoted Post
I found various info about VH Vacationer introduction.
1. Nov 81, Jan 82, Oct 82, Apr 83.
2. Nov 81, Oct 82, Apr 83 and Nov 83.
Which of these is correct? Are Vacationer, Vacationer II and Vacationer III similar? I used to think there were only three issues (81, 82, 83), but it looks like there were 2 issues in 1983.
All 3 VH Vacationers, were just badged "Vacationer", there were no II or III versions. To my knowledge, the only time they had a Vacationer II, was for the HJ series.
AFAIK all Vacationers were released just prior to the Christmas/summer holiday period as a retail special package. The 'on sale' dates I have for the 3 VH Vacationers are Oct 81, Nov 82 & Oct 83 respectively. I checked my old Redbooks & they list the same dates. Where are you getting these other dates from ?
Originally Posted by: hainzy Go to Quoted Post
My VH SL/E top 30 dealer special is dated Nov 81 so they must have pumped them out pretty early as a gift to the dealers. Would have been a pretty cool thing to get back then right at the start of the VH run.
I think that the Top 30 SL/Es, being a special dealer item were probably planned before the VH release & then built early production.
The date I have for the Top 30 is 21 Dec 81 for the media release & because these cars weren't actually 'sold', they were presented to the dealers virtually on that day.
Dr Terry.
Dr Terry,
I know I’m a bit late to the party but I thought I’d jump in.
My (Dad’s originally) VH Vacationer 4.2 has Nov 83 stamped on the info plate. He bought it from Ron Hodgson’s in June 84 after looking at the VK’s earlier and not liking the look of them, plus they didn’t have the 4.2 and he had a caravan trip planned. They had two left, 1 of the ?gold? and 1 of the blue. He liked the Pacific Blue much better and grabbed that one.
So, they were built into Nov 1983. I assume to finish off the 4.2 in Commodore, and to have stock until the VK took off.
Model VH8VK69
Body No 111820 - A
Trim 3042 - 23X
Paint 2B 035-D
Built NOV 83
Eng L36 Trans M40 Axle GU7
When I got the car I sent the details to Holden and their reply was it is a VK…
It isn’t.
Current daily drivers
VFII Sportwagon SV6; BF Astra RS
In the shed
VH Vacationer Pacific Blue 4.2
#234 Posted : Saturday, 28 June 2025 2:26:59 PM(UTC)
November 1983 would be normal for VH. I have ID tags images off VH's in January 1984 and I'd bet there would be at least a Feb 1984 as well.
Blu253 on 28/06/2025(UTC)
Blu253 Offline
#235 Posted : Saturday, 28 June 2025 3:52:28 PM(UTC)
Blu253
Yeah thanks for that info. ThumpUp
I was talking to the VH Vacationer batches specifically. The suggestion I thought was that they were done in batches in 81, 82, and Oct 83. But at least some were built in Nov 83.
I wondered, or assumed maybe, that the Oct 83 may have been the 3.3 and maybe the Nov 83 batch was for the departing 4.2. Maybe to clear the Commodore edition Blue 4.2?
Were the VH & WB 4.2’s coded differently?
Edited by user Saturday, 28 June 2025 3:53:10 PM(UTC)  | Reason: Not specified
In the shed
#236 Posted : Sunday, 29 June 2025 10:28:40 AM(UTC)
Yes they were. Commodore 4.2 had a VR engine no. prefix, while WB 4.2 had a WR prefix.
They were very different engines to look at. The sumps & engine mounts were different as were all of the alternator, compressor & power steer mountings & locations.
Blu253 on 29/06/2025(UTC)
#237 Posted : Sunday, 29 June 2025 12:08:28 PM(UTC)
There would be no reason to “clear” 4.2 engines. There would be one engine manufactured for every car scheduled. If something happened and they were one engine short they’d simply build another one for the car.
The January 1984 car I mentioned is an L36 M40 and there will be plenty more. Note that as Dr Terry says the WB and VH engines are very different. But auto and manual are different engines too. Manuals come to the VAP’s with clutch and bellhousing, plus the dizzy is different, and the manuals have no EGR valve on them, the location is blanked off. So at that time there was at least 4 x L36 engines.
Edited by user Sunday, 29 June 2025 12:15:07 PM(UTC)  | Reason: Not specified
Blu253 Offline
#238 Posted : Friday, 4 July 2025 11:53:55 AM(UTC)
Blu253
With the V2 - VZ Monaro's, is the VZ the only one with the boot robbing US fuel tank?
Or did that come in part way through the V2 SIII ?
In the shed
#239 Posted : Friday, 4 July 2025 12:17:30 PM(UTC)
I'm sure it was only the VZ Monaro which had the boot-mounted fuel tank, with the relocated filler flap.
Blu253 on 4/07/2025(UTC)
#240 Posted : Friday, 4 July 2025 1:56:33 PM(UTC)
I think it was done in export V2, I saw some in Hawaii that were obviously not VZ but looked to have the different fuel filler. But as Dr Terry says for Monaro it was VZ. I looked at them when new and I didn't buy a VZ primarily as the boot was useless but I also didn't want the ugly bonnet vents, so we bought a low kM V2. I was even offered a brand new V2III CV8R really cheap, it was an old stock car but still not yet registered, but I didn't want red or a sunroof.
Edited by user Friday, 4 July 2025 1:59:25 PM(UTC)  | Reason: Not specified
Guest (13)
13 Pages«<10111213>
This page was generated in 0.103 seconds.
