Joined: 15/09/2022(UTC) Posts: 99 ![Australia Australia]() Location: Perth Thanks: 41 times
Hi
Replacd modulator using factory gasket & pissing fluid between modulator & trans case.
Read somwehere not to use gasket but use an aviation type gasket goo, brown sticky stuff
anyone had similar issue ?
It could be that the modulator gasket is not leaking, that in itself is quite unusual. There is a much more common leak nearby, where there is an aluminium plug held in by a pin. It's o-ring needs to be replaced. The pan has to be removed to do the job. It is a task that might be beyond the skills of a DIY guy. Dr Terry |
It could be that the modulator gasket is not leaking, that in itself is quite unusual. There is a much more common leak nearby, where there is an aluminium plug held in by a pin. It's o-ring needs to be replaced. The pan has to be removed to do the job. It is a task that might be beyond the skills of a DIY guy. Dr Terry Thanks, I fixed it, discarded the gasket & used the Loctite brown aviation gasket goo. Worked atreat Now the bloody thing wont hold on Park !
